 cam change
View previous topic View next topic Go down
southark
PostSubject: cam change   Wed Nov 27, 2013 12:18 am
Well here is a update on my cam change.I change my cam out on my 700 rhino and put in a stock raptor cam,and it mad a hell of a differnce on the bottom end and mid range.I'm running 30'' tires and it doesn't have any problem turning them now.To also add with the BAD ASS JBS sheave and msd this thing really came alive.cheers
PostSubject: Re: cam change   Wed Nov 27, 2013 1:51 am
I'm thinkin bout doin a cam.  how long did it take ya and how tough was it?
PostSubject: Re: cam change   Wed Nov 27, 2013 7:55 am
What cam did you have before ?
JBS built 787
JBS sheave
Ported head +2 valves
Power steering
Tilt wheel
Suspinsion seats
Muzzy dual exshaust
Stage 4 elka shocks
Pit bull 26.5 Rockers
Bored throttle body
Low Flyer
PostSubject: Re: cam change   Wed Nov 27, 2013 11:34 am
Nice!  Doing the cam was the biggest improvement that I have done to mine.  Good job and congrats.
Gil
2008 700
Wiseco 11:1
Raptor stage 1 cam
ARP head studs
MSD FI w/ HW maps
Muzzy
Engine Ice
16g OD greaseless weights & Gold Spring
Douglas beadlocks
26" Big Horns
Cognito Racing spindles
Electra power steering
2" spacers all around
4-point harnesses
UTV Concepts cup holder w/ volt, oil, and temp gauges
Equus 8k tach
J-strong doors w/ OEM latches
Ryde'on dust guard
Superwinch 2500lbs w/ 10ft wired remote
Yamaha crossbed tool box, windshield & roof
backup lights
2" lift
southark
PostSubject: Re: cam change   Wed Nov 27, 2013 1:53 pm
I had just the stock cam in it and it wasn't a bad job at all. It took me about a hour and half to do it and that's with my kids running around the shop in the way lol.
PostSubject: Re: cam change   Wed Nov 27, 2013 2:21 pm
Dancing Banana
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
http://www.youtube.com/user/WVHotRodRhino
04rhino
PostSubject: Re: cam change   Sun Dec 01, 2013 1:38 pm
I have been thinking about switching from my stock 04- 660 to the Raptor cam..looking for more bottom & mid-range...did you have much fuel / timing issues ?  are you carbed or Fuel inject ?  Danny
Low Flyer
PostSubject: Re: cam change   Sun Dec 01, 2013 3:58 pm
Hi Danny, it's a 700, therefore it's fuel injected.
2008 700
Wiseco 11:1
Raptor stage 1 cam
ARP head studs
MSD FI w/ HW maps
Muzzy
Engine Ice
Douglas beadlocks
26" Big Horns
4-point harnesses
Equus 8k tach
Ryde'on dust guard
backup lights
2" lift
PostSubject: Re: cam change   Sun Dec 01, 2013 10:41 pm
I absolutely love my stock raptor cam, so much better for my style of riding than the stage3 I had before.
27" EFX Motoclaws
JE 11:1 102mm
Warn Pro Vantage 3500lb.
Ricochet a-arm skids
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: cam change   Mon Dec 02, 2013 1:41 am
is a raptor stage 1  cam the same as a  hotcam  stage 2?
PostSubject: Re: cam change   Mon Dec 02, 2013 4:48 am
a hotcams raptor stage 1 is the same as the rhino stage 2 just a different part number
PostSubject: Re: cam change   Mon Dec 02, 2013 8:22 am
Good to know Raptor stage 1 is the way to go for me.
PostSubject: Re: cam change   Mon Dec 02, 2013 9:20 pm
that's what im running in my rhino seems to be a good all around cam no low end lag an good mid-top end.
Bayou Tiger
PostSubject: Re: cam change   Mon Dec 02, 2013 9:28 pm
Glad to hear....I have one I'm about to install in mine.
2012 700SE
doober
PostSubject: Re: cam change   Thu Dec 05, 2013 11:13 pm
do you need a programmer with these?
cam change
View previous topic View next topic Back to top
» Change shaft - Advice pls
» 200 exc piston change
» Time to change the timing chain?
» Change of direction. Bought a Carbed LT1(?) 86 944 Test Mule
» First oil change - no oil to be seen in inspection hole
