 Stock 2006 450 Rhino
buddalo
PostSubject: Stock 2006 450 Rhino   Tue Dec 03, 2013 9:13 pm
Engine starts up and idles good but at WOT it hesitates every few seconds.
Has sat for over 6 months, changed the plug, fuel filter, air filter, cleaned the fuel pump and carb.  Less than 2 hours on engine since Yamaha shop did complete service.  Put in new CDI box still runs the same.  Am I missing something? Crying or Very sad
Buddie
moobster
moobster
PostSubject: Re: Stock 2006 450 Rhino   Tue Dec 03, 2013 9:34 pm
Sounds fuel related to me. Cracked fuel line???
05 660, 27" Innova Mud Gear tires, 14" ITP 212's, 2" lift, Full Poly cab w/ Heater, Pine Tree air freshener, 14g rollers, Orange spring, Dynatek cdi, Full Poly skids. santa might send me a clutch for Christmas, I've been good all year.
PostSubject: Re: Stock 2006 450 Rhino   Tue Dec 03, 2013 9:59 pm
If your fuel pick up and lines are OK them an electric fuel pump may be the answer.
PostSubject: Re: Stock 2006 450 Rhino   Tue Dec 03, 2013 10:13 pm
If the 450 sat for 6 month there is a good chance the fuel is old in the tank. The second thought is if you're running WOT you're more than likely bouncing off the rev limiter. Put a dyna-tech CDI on the 450 and eliminate the rev limit problem, plus pick up some more top-end on your Rhino. Get with JBS and he'll fix you up with the CDI if you go that direction. Drain the old fuel put some 90+ octane fuel in there run it and see if that solves the problem, but if you're holding it WOT and it hits the rev limiter it's going to have a dead spot until the revs die down them rev back up and do it all over again.......... Got a 450 myself know how they respond.
08/700 SE;Stocker
moobster
moobster
PostSubject: Re: Stock 2006 450 Rhino   Tue Dec 03, 2013 10:32 pm
Never thought about old fuel, that makes a lot of sense. Regular fuel lasts about 3 months, High test lasts about 6 months.
buddalo
PostSubject: Re: Stock 2006 450 Rhino   Wed Dec 04, 2013 1:40 pm
Thanks everyone now I know what to do.  The new CDI is from James and I also got his sheave. It now goes 4mph faster with more power.Smile
Buddie
» CAMO PLastics off of 2006 RHino
» FREE: 2006 660 Rhino Factory rear skid plate
» A arm guards
» Rhino Rear Brake AWFUL Noise -- Normal??
» Rhino 660 OEM drive belt----------SOLD
