 carb needle spring
PostSubject: carb needle spring    Thu Dec 05, 2013 3:28 am
i went to take the needle out of the slide an when i pulled the clip out the little spring went flying an i can find it anywhere ive done it before but always found it this time i think its gone lol anyways does the needle need to move in the slide or can i just put something in the to keep the needle tight?
shortbus453
PostSubject: Re: carb needle spring    Thu Dec 12, 2013 6:03 pm
I worked on mine the day before you, and lost my spring.  After searching for 3 hours and giving up, I found it.  I can tell you that they do run without the diaphram spring installed...funny how I know that.
The only way that I have found that you can get a new spring is with the whole needle assy.
I think that the needle needs to be able to move a little bit.  This helps in to find its home when the throttle is closed.
carb needle spring
» Honda-Clipping the Carb Spring
» spring jam at windrock
» carb vacuum slide
» Duxford Spring Air Show
» WR SPRING JAM 2010
