In total there are 6 users online :: 0 Registered, 0 Hidden and 6 Guests :: 2 Bots
 ITP SD 14" Dual Beadlocks
PostSubject: ITP SD 14" Dual Beadlocks   Thu Dec 05, 2013 6:49 pm
I am thinking about taking my MSA M12's off and selling them and getting a set and was wondering if anyone else has seen them in person or knew anyone with them they look AWESOME and the thought of dual beadlocks is a nice thought deep in the woods on the trail. I have already blew a outer bead while spinning a donut in the woods on the trail and not cool shocked my tire stayed on wheel but my Blackwater Evo's are tuff.
PostSubject: Re: ITP SD 14" Dual Beadlocks   Sat Dec 07, 2013 8:42 pm
I've been looking at some MSA wheels. Not a bead-lock, what do you think of the Diesels you've been running, other than spinning it off the bead?
08/700 SE;Stocker
PostSubject: Re: ITP SD 14" Dual Beadlocks   Sat Dec 07, 2013 8:57 pm
Awesome wheels I love them and will probably just keep them and beat the hell out of them since they have a structural lifetime warranty. I like that not alot of people around here run them most have ITP or STI.
PostSubject: Re: ITP SD 14" Dual Beadlocks   Sat Dec 07, 2013 10:20 pm
I've rolled the bead on my ITP wheels, only once on a rear wheel. But I always have grass hanging out of the bead, I run slime in my wheels which I think helps.
08/700 SE;Stocker
PostSubject: Re: ITP SD 14" Dual Beadlocks   Sat Dec 07, 2013 10:37 pm
I am gonna keep my M12's till summer and then I will likely pull the trigger on those ITP SD dual beadlocks just cause I like the idea of being bullet proof and getting home no matter what. I just dropped all my cheddar on a 30" SR 10w cree bar from Flimmy and a Alba full exhaust from Nate this week so I better relax for a while so I stay married at least a couple more months.
PostSubject: Re: ITP SD 14" Dual Beadlocks   Sun Dec 08, 2013 12:08 am
that's cool they come with skittles  that look like bolts...  Smile  jk.  I think they look cool
PostSubject: Re: ITP SD 14" Dual Beadlocks   Sun Dec 08, 2013 12:41 am
pretty sure they are just a grade 8 bolt color and not multi colored
jmp30
PostSubject: Re: ITP SD 14" Dual Beadlocks   Mon Dec 09, 2013 10:08 am
Those bead locks look good. I'd love to see those Blackwaters on some bead locks. Maybe it would force me to get a set as well.
2013 Realtree Rhino
PostSubject: Re: ITP SD 14" Dual Beadlocks   Mon Dec 09, 2013 10:40 am
I think these are 12" wheels instead of 14" wheels but you get the point.
jmp30
PostSubject: Re: ITP SD 14" Dual Beadlocks   Tue Dec 10, 2013 8:40 am
Yeah I like those pretty good. I never really thought about bead locks and then I started shopping. No bead lock is cheap but if I ever threw down the cash on a set these would be it.
Or these
2013 Realtree Rhino
