In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests :: 2 Bots
 Spacers
PostSubject: Spacers   Tue Dec 10, 2013 12:25 am
I am thinking of installing front spacers,1-2 inch what are your thoughts on this.Is there going to be too much bump steer or bearing problems.
Snorider
PostSubject: Re: Spacers   Tue Dec 10, 2013 12:43 am
I think it wouldn't be a bad deal. more stable and you already have fender flares so you're covered there.
it would stress the bearings more. especially since they take more abuse. but I'm not sure how much faster it would make them wear out. I would think that with an inch spacer it wouldn't be drastic. as for the bump steer, I'd hope that someone with front spacers or LT or MT that doesn't have power steering chimes in
08 700 special-cam/muzzys/3d msd/sheave 16g grease-less greased weights/gold spring w/friction washers/slugged/wide spool viper/26" blackdiamond XTR's on stock alum rimsĀ Smile love it Dancing Banana
PostSubject: Re: Spacers   Tue Dec 10, 2013 12:47 am
Thanks,if it didnt jerk the wheel then I think I will try them,1 inch.
UnderDawg
PostSubject: Re: Spacers   Tue Dec 10, 2013 12:57 am
I haven't noticed any ill effects from running 1'' spacers on the front.. with all the sand and mud down here it would be hard to tell about bearings.
09 camo 450
PostSubject: Re: Spacers   Tue Dec 10, 2013 12:59 am
Sounds good thanks.
PostSubject: Re: Spacers   Tue Dec 10, 2013 1:21 am
Martin, I've ran 2" spacers on my 06/450 for several years and have seen no problem with the wheel bearings or steering. I feel that it's given me much better stability on off-camber situation. The reason I went with the 2" spacers on all 4 corners was I went with a 3" lift and wanted to even out the bike. I've enjoyed the spread and lift both.
08/700 SE;Stocker
Pensfan87
PostSubject: Re: Spacers   Tue Dec 10, 2013 7:27 am
How about 1.5" spacers? I put them on my '12 700 four months ago. Haven't noticed anymore or any less bump steer, but does feel more planted in the off camber turns. 1.5's brought the front wheel stance out even with the back.
2012 Yamaha Blue Rhino
72" Eagle Snow Plow
3000 lb. Warn Winch
Combs Customs Full Tinted Windshield
Yamaha OEM Sun Top III roof
Yamaha OEM Rear Storage box
Black Rhino Rear Diff Brace
Black Rhino Body Rivet Kit
2" Homemade lift
PostSubject: Re: Spacers   Tue Dec 10, 2013 9:05 am
Thanks guys now I have a lot to think about,good suggestions.
Spacers
» Spacers
» Pair 1'' wheel spacers polaris
» polaris wheel spacers
» New "Cooter Brown" RZR Tops and Wheel Spacers
» Wheel Spacers
