In total there are 15 users online :: 0 Registered, 0 Hidden and 15 Guests :: 1 Bot
 One way bearing direction
skeeter660
PostSubject: One way bearing direction   Wed Dec 11, 2013 12:50 am
I did not pay attention to the way in came out there is writting on one side and not the other the writting says out side but im unsure what side they mean to be out side
PostSubject: Re: One way bearing direction   Wed Dec 11, 2013 1:11 am
the side that says outside should be facing the clutch meaning when u put the oneway in the housing u shouldn't see the words it will be facing the shaft off the wet clutch drum
Low Flyer
PostSubject: Re: One way bearing direction   Wed Dec 11, 2013 1:16 am
That is correct.  The writing will be facing the the driver's side of the rhino, away from the motor.
Gil
2008 700
Wiseco 11:1
Raptor stage 1 cam
ARP head studs
MSD FI w/ HW maps
Muzzy
Engine Ice
16g OD greaseless weights & Gold Spring
Douglas beadlocks
26" Big Horns
Cognito Racing spindles
Electra power steering
2" spacers all around
4-point harnesses
UTV Concepts cup holder w/ volt, oil, and temp gauges
Equus 8k tach
J-strong doors w/ OEM latches
Ryde'on dust guard
Superwinch 2500lbs w/ 10ft wired remote
Yamaha crossbed tool box, windshield & roof
backup lights
2" lift
skeeter660
PostSubject: Re: One way bearing direction   Wed Dec 11, 2013 3:16 pm
Ok cool thanks guys, I started it up and heard something in there rattling so im probably to late, if you dont care about engine braking is this something u have to have in there
Quadog
PostSubject: Re: One way bearing direction   Wed Dec 11, 2013 3:49 pm
I ran mine with a bad one way bearing for a year or so before I even knew there was anything wrong with it. I got my Rhino used, so I didn't realize it was bad until I was in another Rhino. I changed mine so I had engine braking but I don't think it was actually hurting anything. Sometimes it made a growling noise on deceleration but it would probably have went away as the bearing wore out more.
2008 700 Sport- 27" ITP XTRs -ITP Type 7 Series rims-2' lift- HotRodRhino Sheave -16od w/ gold spring- Dyna FS CDI- Pro Armor A-Arm guards-3500# winch-Full Tommy Topper- Summit Heater...More to come...Stay Tuned
PostSubject: Re: One way bearing direction   Wed Dec 11, 2013 4:23 pm
only bad thing is that if it grenades you have to go fishing for pieces
JBS
