 Installing Hot Rod Cam videos?
View previous topic View next topic Go down
PostSubject: Installing Hot Rod Cam videos?   Wed Dec 11, 2013 1:16 am
Getting ready to install Raptor cam in my 700 and was wondering if there was any good vids to review before hand. Didn't really find anything to good on the web. Anyone know of a good site? Pretty much a knuckle buster mechanic. Thanks.
08/700 SE;Stocker
PostSubject: Re: Installing Hot Rod Cam videos?   Wed Dec 11, 2013 8:24 am
Be sure and tie the chain up to the cage somehow ,  so it won't come off the bottom gear !!  After lining everything up ,  we used a sharpie and made our own "marks"...just to be sure nothing moved.  The tappet tool really makes it easier adjusting the valves ,  too  !!
PostSubject: Re: Installing Hot Rod Cam videos?   Wed Dec 11, 2013 11:03 am
Scott, is that the 'off-set feeler gauges' or the 'tappet valve tool' or both? Never had heard of a tappet tool and looked on flea-bay?
08/700 SE;Stocker
PostSubject: Re: Installing Hot Rod Cam videos?   Wed Dec 11, 2013 11:16 am
Looked on the bay just now...didn't see what I'm talking about....maybe James will pipe in , and tell ya the name brand of the tool. If you do a search for motorcycle valve adjusting tool , you'll see what I'm talking about. Regular feelers will work.
PostSubject: Re: Installing Hot Rod Cam videos?   Wed Dec 11, 2013 11:19 am
motion pro...i love mine!!
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
http://www.youtube.com/user/WVHotRodRhino
PostSubject: Re: Installing Hot Rod Cam videos?   Wed Dec 11, 2013 12:19 pm
It allows you to break loose the jamb nut and adjust the valve with one tool in one go.
2006 Rhino 660
HID conversion
Quick detach snow plow
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: Installing Hot Rod Cam videos?   Wed Dec 11, 2013 12:31 pm
Yep, Motion Pro, seen them advertise. Wondered how they worked, looked like a socket on a breaker-bar. Sounds like a nifty tool to have in the tool chest. Thanks.
08/700 SE;Stocker
PostSubject: Re: Installing Hot Rod Cam videos?   Wed Dec 11, 2013 2:30 pm
x2 on the witness marks as per scott; take a picture with everything in place and marked for reference before you tear it down.
JBS
View previous topic View next topic Back to top
» installing a bypass (On/Off) switch onto an External speaker
» Installing Symtec grip heaters on K100RT++
» Jamaica v USA in 104th Millrose Games & Videos
» Installing a Gerbings Dual Permanent Controllers on my RS
» Can-Am videos now on YouTube
