In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests :: 1 Bot
 2006 HID Conversion
View previous topic View next topic Go down
shortbus453
PostSubject: 2006 HID Conversion   Wed Dec 11, 2013 4:38 pm
Anyone have a recommendation for a HID Conversion to the 2006's?  I would really like to get a kit that  has Hi/Lo, and also has a decent mount.  From what I was able to find, it looks like the kit that SideXSide Customs had was the hot ticket, but it looks like they are not around any more.
CamoRhino660
PostSubject: Re: 2006 HID Conversion   Wed Dec 11, 2013 8:35 pm
They are around just takes some searching to find him. He is a good guy. Got mine from rigid. Had to upgrade to newer light housing to be able to get the high/low. Very simple swap and would highly recommend the rigid kit. Got mine from benchmark.
PostSubject: Re: 2006 HID Conversion   Thu Dec 12, 2013 8:30 am
I have a set in my Rhino...but i would say you might want to rethink it. They are an improvement over the stock headlights no question. BUT I would go with some lights from Flimmy. I did a 10" light bar and you cant even tell the HID's are on when that is on. Plus it draws less power than the HID's do also (and we all know the Rhino's charging system is nothing to write home about). Or if you want to stay with headlights do the round LED conversion that has been going on around here for the last little bit. You will be better off in the long run.
2006 Rhino 660
HID conversion
Quick detach snow plow
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
2006 HID Conversion
View previous topic View next topic Back to top
» Parts List for the Conversion
» s13 ISIS Dual 3" Exhaust & OEM 5 Lug Conversion
» 4aelu or efi parts/ conversion
» Xenon conversion
» SBC oilpan conversion question.
