| Another newbie successful JBS sheave install ! | |
+9madmax 1 dognhogs Firefighter WV Hot Rod Rhino meats Hump ASPENDELLROVER flimmy mnormand 13 posters |
mnormand
Posts : 14 Join date : 2013-03-10 Location : S. La.
| Subject: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 12:26 am | |
| 2009 700FI, camo DU, 1500miles, 236hours, 2in lift, 30" Mud Lites XXL Had the sheave kit for a week plus, but things kept coming up preventing me from starting the project. Decided to try it after work today, started at 4pm, finished about 8pm. Between chasing tools, running inside for video instruction updates, it went smooth enough. Except I couldn't get the secondary spring off with the tire method! Didn't expect that, heck I weigh 210 but couldn't even budge it. I really wanted to do the servicing, guess I'll do it next time with a homemade compressor from the threads here I just discovered. Per James' suggestion, I'm now running his greased sheave, 18gr weights, new OEM belt, and stock spring. I was very careful installing that sheave properly on the shaft, and it went on much easier than I thought. The other hiccup was when I started to remove the many small screws holding the cap on the old sheave, I freaked out when I almost stripped the first one. Turns out my phillips bit was not quite the perfect fit. Was very careful with screwdriver, and they all came out ok. And I spent 1/3 of the time fighting with the sheet metal and bracing, getting all that lined up and bolted back together. Buttoned everything up under the lights, and rode around the small back yard for a whole 30 yards or so, everything works fine, no strange noises, and I can definitely tell the difference. No hesitation, very smooth. Looking forward to trail riding with the 30" Mud Lite XXL tires recently installed. Should be a great combo now! Nothing like the first time! Next service attempt will go much quicker ! Thanks James for all the vids ! (ps: I'm the one who needs that missing Yamalube tub when you get more...thanks for the ziplock of grease! Also need about 10 of those ridiculous plastic screw/expanding anchor thingys. ) | |
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 12:31 am | |
| Yea I'm 230 and it was a little tough getting the spring compressed but I got it done. dont wait too long to change the spring , you want all you can get out of the mods | |
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 1:00 am | |
| are they any skinny rhino owners? lol..I'm 200lbs but still nimble and quick as a cat..lol...I always say if I lost 30 lbs my my rhino would be fast, but then I'd look like the UTV stink guys..lmao | |
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 1:13 am | |
| I hope you mean 14g weights and not 18s. If you told James you were running 30s on it, he would have sent you the 14s I bet. If not, you need the lighter weights with those tires. Anyway, you are gonna like it, and maybe even love it after you get that spring in there. The 1st spring I changed using the wheel as James said, I couldn't compress it while taking it apart. I just put my whole 190 on it and took the nut off, nothing bad happened. When I put the new spring on, I compressed it with no trouble and it was stiffer than the stock one. Made no cense to me, but that's how it went. Congrats on one of the best mods you can make! | |
meats
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 9:17 am | |
| i cant wait till i get my sheave kit hope its in shortly, all my buddys are going out and buying commanders it should keep me close in the tight trails i hope | |
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 9:28 am | |
| if they dont have a cdi they have to run 18gr or it will hit the rev limiter while accelerating.... | |
mnormand
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 10:09 am | |
| Thx all. No CDI here, 18gr is what the carton said, thx James for confirming. I had discussed this with him, my riding style is low and slow, hardly ever going to go wide open, or maintain high rpms. Probably wouldn't be a good idea as its pretty tall now. I picked up some free rear spacers from the dealer recently, but haven't put them on yet, not sure if I will. Might cause new tire rubbing issues, and also hate to have mud slinging all over me with wider tires. I sure wish I had places to ride out the back door like some of you, especially in the hills. I love to bowhunt deer with trad gear, and would be after them nonstop, LOL. Next project later is going to be some nice switch panels like ChrisH, for my Rhino, boat, and 4runner. | |
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 10:29 am | |
| Glad You got it in and going. The more You ride it, the more You will like it ! Have fun with it ! | |
dognhogs
Posts : 21 Join date : 2013-03-21 Age : 34 Location : Arkansas
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 11:20 am | |
| im waiting on my kit from james to come in. The suspense is killing me, ive got everything ready to put back together when it comes in. Im glad to here I aint the only newbie that's installing one by videos. Thanks for the post | |
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 11:49 am | |
| glad to her things went good for you ,will be doing mine in a week or so, as soon as antifriction disc come ,very excited | |
slomo
Posts : 48 Join date : 2013-03-12 Age : 49 Location : Sherwood park Alberta
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 12:17 pm | |
| I have ridden mine for a week since I greased,installed 14g weights and friction washers and it is a completely different machine it gets up and goes:) | |
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 12:57 pm | |
| - WV Hot Rod Rhino wrote:
- if they dont have a cdi they have to run 18gr or it will hit the rev limiter while accelerating....
I never even thought about that. It would really pull those tires with the cdi and lighter weights, but it sure would make some noise. Speaking of making noise. We are getting used to the high revs with the 16s and exhaust tip, but I don't think the neighbors are. LOL | |
RiverRat
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 1:38 pm | |
| I made the same mistake with the spring. After a phone call to the hot rod he told me the spring won't compress due to the way the washer sits on it. Anti-friction washers are in sheave serviced and now I need go fast parts. Thanks again to James for his tolerating my newbie questions. | |
Snorhino
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 8:50 pm | |
| All the talk here convinced me to order a sheave kit from James this week as well, looking forward to the upgrade. Doing my springtime routine of pulling off my tracks and putting the tires on as well as a service so I figured it was time for the upgrade. Hopefully will keep me close to my brothers new Deere 835. | |
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 9:25 pm | |
| - Snorhino wrote:
- All the talk here convinced me to order a sheave kit from James this week as well, looking forward to the upgrade. Doing my springtime routine of pulling off my tracks and putting the tires on as well as a service so I figured it was time for the upgrade. Hopefully will keep me close to my brothers new Deere 835.
You will be very happy, is it one of those new gators. | |
Snorhino
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 9:30 pm | |
| It is a gator, big upgrade from the old ones, we used it some hunting appears to be a good rig | |
RiverRat
| Subject: Re: Another newbie successful JBS sheave install ! Fri Mar 29, 2013 9:38 pm | |
| Wow. Greased sheave and anti friction washers are great. This thing just keeps getting better. | |
| Subject: Re: Another newbie successful JBS sheave install ! | |
