| trans binding | |
| Subject: trans binding Mon Mar 25, 2013 4:12 pm | |
| I went out today to plow the driveway and the trans wont shift correctly. It is binding were you have to sometimes rock the rhino to get it to shift. I havent pulled the cover to check the sheave yet but before I do what should I be looking for ? It also seems to want to move at idle. | |
| Subject: Re: trans binding Mon Mar 25, 2013 4:18 pm | |
| nothing with the shift linkage is there | |
| Subject: Re: trans binding Mon Mar 25, 2013 4:23 pm | |
| idling to high or wet clutch not dis engaging ? | |
| Subject: Re: trans binding Mon Mar 25, 2013 4:37 pm | |
| check idle..wet clutch or one way..sheaves wont make it move at idle | |
| Subject: Re: trans binding Mon Mar 25, 2013 4:55 pm | |
| Idle is low and I was thinking wet clutch because I had to rock it back and forth to get it to shift. It stalled a few times and when I went to start it acted like it wanted to move. Looks like I'll be puling it apart this week. | |
| Subject: Re: trans binding Mon Mar 25, 2013 4:56 pm | |
| something happened to the one way im thinking | |
| Subject: Re: trans binding Mon Mar 25, 2013 4:59 pm | |
| ok , do you have any videos on the oneway ? | |
| Subject: Re: trans binding Mon Mar 25, 2013 5:02 pm | |
| i will make on when i do my slug kit tonight | |
| Subject: Re: trans binding Mon Mar 25, 2013 5:07 pm | |
| Could the super cold cause the one way bearing to seize ? Especially if it has a little moisture on it. | |
| Subject: Re: trans binding Mon Mar 25, 2013 5:20 pm | |
| the spring gets weak and they just wear out every 1500 to 5000 ....lol..depends on ridn style | |
| Subject: Re: trans binding Mon Mar 25, 2013 5:39 pm | |
| Firefighter it's not that cold, I really didnt need to plow the driveway. I plowed more snow out in the field because I hadn't got to use it this winter. And my riding style is either on the gas or off . plus I bought the Rhino used and dont know how it was treated before I got it. | |
| Subject: Re: trans binding Mon Mar 25, 2013 5:46 pm | |
| oil changes is the life of them....dirty oil eats stators too.. | |
| Subject: Re: trans binding Mon Mar 25, 2013 5:51 pm | |
| Ahhhh. And I guess the one way runs in oil anyway. | |
| Subject: Re: trans binding Mon Mar 25, 2013 5:53 pm | |
| Oil is new , I just bored it and put a new piston in less then 15 hrs ago , changed the oil and used Yamalube performance all purpose 10w-40 | |
| Subject: Re: trans binding | |
| trans binding | |
