 lsr mid travel...
Go to page : 1, 2  Next
skeeter9
PostSubject: lsr mid travel...   Sun Mar 10, 2013 10:40 pm
Ok there are thick bushings and thin and the destructions don't tell me which go where.... Someone please help a brutha out with this... affraid What a Face
dunerdan
PostSubject: Re: lsr mid travel...   Sun Mar 10, 2013 11:20 pm
post some pics.
bushing s for a arms?
skeeter9
PostSubject: Re: lsr mid travel...   Sun Mar 10, 2013 11:37 pm
Yes for the a arms and my shed is all closed up I'll get some next time I am out there
dunerdan
PostSubject: Re: lsr mid travel...   Sun Mar 10, 2013 11:43 pm
sounds good
skeeter9
PostSubject: Re: lsr mid travel...   Mon Mar 11, 2013 10:56 am
I figured it out the thin are for lower front arms because that's where you put spacers to adjust high low on steering it clicked last night...
dunerdan
PostSubject: Re: lsr mid travel...   Mon Mar 11, 2013 4:46 pm
nice!
skeeter9
PostSubject: Re: lsr mid travel...   Tue Mar 12, 2013 3:47 pm
I also pulled my sway bar off what's consensus on that... I don't ride the sand or haul the mail on desert I'm a trail and I wonder if I can make it through there kinda guy....
Greeley
PostSubject: Re: lsr mid travel...   Wed Mar 13, 2013 12:45 pm
I left mine on, I like having it on for the riding I do which is mostly CA/AZ desert fast speed stuff. Taking it off will give you more body roll but that could be an advantage depending on what type of riding you do. If you do slow rock crawling or slow speed stuff going over obstacles etc, it might be better to have it off. Give it a shot without, you will find out real quick if you like it or not and can always put it on later if you don't.
skeeter9
PostSubject: Re: lsr mid travel...   Wed Mar 13, 2013 3:52 pm
That's what I was thinking too ill just take it with me and if anything I can remount it and just leave it disconnected if don't like it slap it back on....
Baxter Built Fabrications
PostSubject: Re: lsr mid travel...   Thu Mar 14, 2013 6:23 pm
The spacer you refer to adjusts you caster angle.Your manual will explain
what it does to your handling.One way makes it handle bettter at high rates of speed but makes it harder to turn the wheel and the other will make it easier to steer and make it wonder at high speeds.Can't remember witch is witch though.I would think spacer in the front works for high speed handleing but don't quote me.It does make a differance though.I run the same suspension on my 08
skeeter9
PostSubject: Re: lsr mid travel...   Fri Mar 15, 2013 12:09 am
yeah i have only sundays off so its taking some time to get r dun hopefully ill get front done this weekend and can finish up rears next weekend... bad enough 6 day work week but my daughter will arrive any day now so that will cause me to just work on it couple hours here and there while she sleeps lol
skeeter9
PostSubject: Re: lsr mid travel...   Sun Mar 17, 2013 5:00 pm
Ok wtf how do I get the metal clips off that holds boot onto axle so I can install the longer axles
PostSubject: Re: lsr mid travel...   Sun Mar 17, 2013 5:17 pm
I use a wiz wheel on a grinder a some finesse.
skeeter9
PostSubject: Re: lsr mid travel...   Sun Mar 17, 2013 6:04 pm
Ah so they are not simply removable gotta dispose of them after... Gotcha think I'm gonna just call into work and take em to alba one day and have them do it lol I busted my hand so had to call it a day anyway o well at this rate ill have it finished by end of summer Mad lol
PostSubject: Re: lsr mid travel...   Mon Mar 18, 2013 11:33 am
Best bet prob.I've seen guys around here use zip ties.I wouldn't advise that.CV's are not cheap.The good band clamps require a tool to install them.If you have the tool the clamps are cheap and easy to install.They use to send some with the kit from LS but they sucked too.You can do them by hand but getting them tight is a pain in the ass.I opted to get differant ones.
08 Rhino with JBS sheave,LS MTS,27.5 Pittbull Growlers on HiPer beadlocks,4 seat cage,and a 40"E series RIGID LED.
baxters@embarqmail.com  419-953-8509
skeeter9
PostSubject: Re: lsr mid travel...   Mon Mar 18, 2013 1:58 pm
Thanks I think I'm just gonna label all 4 corners take them and new axles and have alba do em for me make my life a little easier lol
08 700
jbs sheave 16s and a purple
muzzy duals
custom intake/snorkel
4 seat cage w/removable rear seat
beadlocks w/26'' bighorn 2.0
msd mapped by alba nate
lsr mid travel w/fabtech dirt logic 2.0 shocks
cfm 2'' lift
Greeley
PostSubject: Re: lsr mid travel...   Wed Mar 20, 2013 7:23 pm
Can we see some pics of this ride already?
PostSubject: Re: lsr mid travel...   Wed Mar 20, 2013 7:52 pm
WHAT !!!!! Daughter going to arrive any day ????
Did You reproduce ?
2014 RZR 800 S Indy Red
SOLD
PostSubject: Re: lsr mid travel...   Wed Mar 20, 2013 8:29 pm
u better save that project, u r gonna need something to tinker on to save your sanity...trust me been there. and remember from now on all money spent the rhino is due to safety for the family, it has worked for me so far..lol
skeeter9
PostSubject: Re: lsr mid travel...   Thu Mar 21, 2013 11:48 am
O yeah daughter got her at 5:58 yesterday afternoon so rhinoceros will be sitting even longer before I can finish now.... O well its in the shed protected from weather so ill just do what I can when I can when I can lol
08 700
muzzy duals
cfm 2'' lift
PostSubject: Re: lsr mid travel...   Thu Mar 21, 2013 12:36 pm
Skeeter is a daddy !!!
SOLD
PostSubject: Re: lsr mid travel...   Thu Mar 21, 2013 6:29 pm
congrats!
skeeter9
PostSubject: Re: lsr mid travel...   Thu Mar 21, 2013 7:21 pm
Thanks fellas
08 700
muzzy duals
cfm 2'' lift
skeeter9
PostSubject: Re: lsr mid travel...   Wed Nov 20, 2013 8:40 pm
well got all arms etc on finally just waiting for the homie at off road warehouse to do my axles for me then I'll slap em on and finish her up
08 700
muzzy duals
cfm 2'' lift
PostSubject: Re: lsr mid travel...   Wed Nov 20, 2013 11:01 pm
Did you need to get longer axles or did you just upgrade the stock axles? We like pics! How's the new daughter doing?
08/700 SE;Stocker
lsr mid travel...
» Prowler Long Travel
» Teryx Long Travel
» Polaris RZR XP 900 Long Travel Kit...Sick!
» Mid Travel Kit.......
» 2010 John-Deere long travel Gator gives Polaris "S' a run for the money
