In total there are 23 users online :: 0 Registered, 0 Hidden and 23 Guests :: 1 Bot
tip on splitiing wet clutch assmbly Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
tip on splitiing wet clutch assmbly Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
tip on splitiing wet clutch assmbly Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
tip on splitiing wet clutch assmbly Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
tip on splitiing wet clutch assmbly Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
tip on splitiing wet clutch assmbly Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
tip on splitiing wet clutch assmbly Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
tip on splitiing wet clutch assmbly Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
tip on splitiing wet clutch assmbly Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
tip on splitiing wet clutch assmbly Vote_lcaptip on splitiing wet clutch assmbly Voting_bartip on splitiing wet clutch assmbly Vote_rcap
RHINOMOON
7 posters
RHINOMOON
RHINOMOON
tip on splitiing wet clutch assmbly Empty
PostSubject: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeSun Apr 21, 2013 12:22 pm
When i did mine, i took everything off except the plastic piece that surrounds the primary and secondary clutches. all i did was take the "breather tube" off that is directly on top of wet clutch assembly and used my lil scraper and put it in the "breather hole" and between the two halves and gave it a tap. and it split nicely, i first of tryed using two needle nose plyers inserted in the bolt holes, the whole rhino was shaking as i was trying to pull it off. hope u guys understand what im talking about.. i wish i took piks..hope this helps. if someone can post a pik.. that be great.
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeSun Apr 21, 2013 1:55 pm
Not real sure what your trying to say, as you can't even get to the wet clutch untill the primary clutch is removed. The 700 has a hole on the top for the breather tube, but the 660 is on the low backside. I think pic's would deffinatly help.
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeSun Apr 21, 2013 3:09 pm
not real sure either,maybe you could tear it back apart for some pics, lol!
RHINOMOON
RHINOMOON
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeSun Apr 21, 2013 4:08 pm
hmmm haha.. i have a 700.. after taking the primary sheaves off. your left with the shaft sticking out. and a drum looking thing. thats the wet clutch assembly. remove tube. and insert thin scraper from the top.
tip on splitiing wet clutch assmbly Images?q=tbn:ANd9GcTRZGuJMD3jPkgCXTYQeMx3nBFaMpHFVkeDVpDZwPOJ6V_hA5hk
(pik stolen from internet ,its a grizzly) but you get the idea, i hope
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeSun Apr 21, 2013 8:19 pm
OK, Now I understand, That is a good Tip, as that cover can be a bitch to get off some times. cheers
RHINOMOON
RHINOMOON
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeSun Apr 21, 2013 9:32 pm
stuntman mike approved. haha .BTW sluggin that thing was a great mod.
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeSun Apr 21, 2013 9:40 pm
Glad to hear you like it, Now go blow away some Rzr's tip on splitiing wet clutch assmbly 2016508534
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeSun Apr 21, 2013 10:00 pm
Good info for us newbies. Any way to reuse gasket if it stays intack? Or is one that you always replace? That answer is the only thing keeping me from opening it up, to slug and just get a good look at the whole CVT operation. I don't want to be down, waiting on a gasket.
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeSun Apr 21, 2013 10:38 pm
get gasket , you don't want to risk it
RHINOMOON
RHINOMOON
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeMon Apr 22, 2013 12:11 am
must get a gasket, and its also a good time to get some fresh oil for your rhino too since you must drain it all.
RHINOMOON
RHINOMOON
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeMon Apr 22, 2013 12:13 am
well i can keep up to my buddies 700 grizzly's. so thats gotta be a start. He used to blow my doors off, but now hes pretty impressed what my rhino has become. Ill try to hunt down some rzrs this summer.. well if summer ever shows up. Haha
EddieMc
EddieMc
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeWed May 01, 2013 4:26 pm
yeh i learned the hard way i pryed my "drum" off and cracked it fml
Snorider
PostSubject: Re: tip on splitiing wet clutch assmbly   tip on splitiing wet clutch assmbly Icon_minitimeFri Jun 21, 2013 3:10 am
guess I got lucky then when I slugged mine. my assembly was on there like concrete. after trying several different ways to separate it,  I finally had to use a heel bar very carefully in 3 spots to slowly break it free. didn't break or crack the drum though.Smile thankfully lol
but yea always make sure to have a new gasket on hand if you plan on going into the wet clutch. some guys managed to keep the gasket intact and reuse it, but better to plan on that NOT happening.
» Wet clutch
» clutch
» mud in clutch!
» wet clutch off
» clutch better than before
