 MSD 3D map
Briki
Briki
PostSubject: MSD 3D map   Mon Apr 22, 2013 5:31 pm
Hi James,
I need map for MSD 3D
- Engine mods:
Teamalbaracing BIG BORE CYLINDER KIT 734CC 105.5 CP 11:1 PISTON
Hotcam stage 3
MSD 4245 3D Charge FI Controller
K&N's 63-1121 air intake system
Dual Looney Tuned Exhaust
JBS Sheave 16g overdrive weights & gold secondary spring
- Tire size:
Maxxis Bighorn 27"
- Terrain I ride:
Desert, sand and dunes
- Oct fuel:
91 & 95
Thanks
Mrs. Hot Rod
Mrs. Hot Rod
PostSubject: Re: MSD 3D map   Wed Apr 24, 2013 10:33 am
Hey Briki,
PM me your email address & I will send you something, thanks.
Briki
Briki
PostSubject: Re: MSD 3D map   Wed Apr 24, 2013 11:47 am
Hi Nikki,
Thanks for your help
PM sent
2009 Rhino 700 Sport Edition
Alba Racing Big Bore 734cc + CP Piston 11:1
Hotcams Stage-3
MSD 4245 3D
K&N Intake System
Dual Looney Tuned
KMS Wet Clutch Slug kit
JBS Hot Rod Sheave + 16g OD
Gold secondary spring & Anti Friction Washer
ITP 312S 12" Wheel
Maxxis Bighorn 27"
Glowshift Digital Tach
Innovate Digital Wideband A/F Ratio
Digital LED Water Temp
Pro Armor 4 Point Harness
HID Conversion Kit
Safeglo LED Whips
HOTRODRHINOFORUMS.COM   ©️ 2013
PostSubject: Re: MSD 3D map   Wed Apr 24, 2013 6:06 pm
James or Nikki:
If you have a MSD 3D map for a 734 build, would you mind emailing it to me? I only have the stage 2 cam compared to Briki's stage 3. I am considering removing my Bazzaz and just using my MSD that I bought from yall.
Also, I've made my own MSD map based on my Bazzaz map generated from the Autotune, but have not tested it yet. Maybe I could email that map to you guys to review and possibly tweak.
Finally, how do you feel about maybe adding a couple of degrees of timing advance to the motor below 5000RPM? Would that be a no-no on with an 11:1 piston and 93 pump gas?
Sorry to come and crash your thread, Briki! It sounds like our Rhinos are similar!
2011 Rhino 734 Sport
2014 Teryx4 800 LE
4500lb Warn
Briki
Briki
PostSubject: Re: MSD 3D map   Thu Apr 25, 2013 8:46 am
Hi Chris,
I read your thread about Installing big bore 734cc in your 2011 rhino. It was great thread !!
After my piston broken last week I decide to go with big bore 734cc like you did.
Thanks for posting learning alot from that thread.
And about MSD map, I'm sorry Chris, where I do not have experience in modifying MSD maps or timing. Only a little knowledge in mechanics enough to make some of my Rhino maintenance.
Hotcams Stage-3
MSD 4245 3D
K&N Intake System
Dual Looney Tuned
ITP 312S 12" Wheel
Maxxis Bighorn 27"
HID Conversion Kit
Safeglo LED Whips
PostSubject: Re: MSD 3D map   Thu Apr 25, 2013 6:07 pm
Cool deal, Briki!
You should post up your thoughts on the 734. I'd be curious to hear if your reactions were similar to mine. I notice the biggest gain at speeds below 40mph. The bottom end is just incredible over stock from my observation! I realize you have a different cam than me, so that might change the power characteristics.
2014 Teryx4 800 LE
4500lb Warn
EddieMc
EddieMc
PostSubject: Re: MSD 3D map   Tue Apr 30, 2013 3:51 pm
would this msd setup be better then my pcv with autotune??
2008 yamaha rhino 4 seater-racerz edge +2 full race port and polish head *alba racing 734 big bore with 11:1 piston*wellerracing crank (stock stroke) pinned and welded*dragon fire racing custom bored throttle body*power commander V (auto tune) *Dynatek ignition box*Muzzy's full dual exhaust*Autometer oil temp gauge *Autometer water temp gauge*Autometer Air to Fuel Ratio gauge Just put new crank, rod, piston, and all bearing and seals purple spring jbs sheave with 14g ods +6 lonestar long travel with bilstein shocks
Briki
Briki
PostSubject: Re: MSD 3D map   Fri Jun 07, 2013 4:14 am
Hi Eddie,
I really do not know which is better and I never tried pcv.
But I like the idea of autotune and I hope to try it in the future.
I think Chris has a better idea on this as he had previously tried bazzaz autotune.
Hotcams Stage-3
MSD 4245 3D
K&N Intake System
Dual Looney Tuned
ITP 312S 12" Wheel
Maxxis Bighorn 27"
HID Conversion Kit
Safeglo LED Whips
PostSubject: Re: MSD 3D map   Mon Jun 10, 2013 2:54 pm
Hey Briki can you take a video and post it of your speedometer from launch up to 45 or 50 mph. I am curious to see how your 734 acts with the Stage 3 cam compared to my 686.
27" EFX Motoclaws
JE 11:1 102mm
Warn Pro Vantage 3500lb.
Ricochet a-arm skids
PRM bash plate
Unisteer Rackzilla
Briki
Briki
PostSubject: Re: MSD 3D map   Mon Jun 10, 2013 3:47 pm
not repair my rhino yet, piston broken and cylinder scratched. I reorder alba 734 again when rebuild it I'll make video. This link for my post about my problem
http://hotrodrhinoforums.forumotion.com/t1303-big-bore-734cc-piston-broken
this old video before big bore & cam
https://youtu.be/9TqcX6qTcBc
Hotcams Stage-3
MSD 4245 3D
K&N Intake System
Dual Looney Tuned
ITP 312S 12" Wheel
Maxxis Bighorn 27"
HID Conversion Kit
Safeglo LED Whips
PostSubject: Re: MSD 3D map   Mon Jun 10, 2013 4:16 pm
I got excited there for a minute before I saw it was kmh.
27" EFX Motoclaws
JE 11:1 102mm
PRM bash plate
Unisteer Rackzilla
Briki
Briki
PostSubject: Re: MSD 3D map   Mon Jun 10, 2013 4:20 pm
About 62 MPH
Hotcams Stage-3
MSD 4245 3D
K&N Intake System
Dual Looney Tuned
ITP 312S 12" Wheel
Maxxis Bighorn 27"
HID Conversion Kit
Safeglo LED Whips
MSD 3D map
