In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests :: 1 Bot
New from Newport, TN Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
New from Newport, TN Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
New from Newport, TN Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
New from Newport, TN Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
New from Newport, TN Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
New from Newport, TN Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
New from Newport, TN Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
New from Newport, TN Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
New from Newport, TN Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
New from Newport, TN Vote_lcapNew from Newport, TN Voting_barNew from Newport, TN Vote_rcap
Chief1979
hymarker
Yotehunter66
m1n1ster
13 posters
Go to page : 1, 2  Next
m1n1ster
m1n1ster
New from Newport, TN Empty
PostSubject: New from Newport, TN   New from Newport, TN Icon_minitimeSat Apr 27, 2013 3:11 pm
Thought my bike was just leaking from rear output shaft, changed seal, went for a ride and when I stopped had a puddle of oil. After further inspection it is the where the crankcase comes together on the bottom opposite the cylinder head. I have never really built or been in this type of engine. My question would be, "Is this something that I could do myself or should I let someone else do it?"
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSat Apr 27, 2013 3:31 pm
welcome man , james will probably have some input for ya ,hang out and look around
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSat Apr 27, 2013 3:33 pm
is it coming from where the 2 halfs of the cases come together , got any pics of the location?
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSat Apr 27, 2013 5:11 pm
New from Newport, TN 2016508534Welcome aboard!! Pics would help a lot.
m1n1ster
m1n1ster
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSat Apr 27, 2013 5:28 pm
It is coming where the two halves come together. Specifically right behind where the m6 bolt is on the bottom.
Yotehunter66
Moderator
Yotehunter66
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSat Apr 27, 2013 5:29 pm
Welcome.
m1n1ster
m1n1ster
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSat Apr 27, 2013 5:31 pm
Sorry no pics maybe try later but it will be hard to get pics because of location.
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSat Apr 27, 2013 11:03 pm
Welcome!!
hymarker
hymarker
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSun Apr 28, 2013 12:32 am
Welcome!
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSun Apr 28, 2013 1:27 pm
welcome lots of good info around here , the leak it's not the drain plug is it ,if the cases need to be sealed can be a big job may want to get a good manual it will help a lot study , then talk with James he will get what you need an answer your questions too .....enjoy the site New from Newport, TN 2016508534
m1n1ster
m1n1ster
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSun Apr 28, 2013 3:36 pm
https://i.servimg.com/u/f80/18/27/13/04/oil_le14.jpg
https://i.servimg.com/u/f80/18/27/13/04/oil_le15.jpg
Here are some pics, they are taken from passenger side. In the first pic you can see the m6 bold, in the second you have to look in the mirror and you can see the oil droplet. Behind there is where it is leaking.
Chief1979
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSun Apr 28, 2013 4:20 pm
Welcome from Cookeville, TN
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSun Apr 28, 2013 7:43 pm
I think that may be your water pump housing , not a bad job if that's it
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSun Apr 28, 2013 9:06 pm
I went out an looked at mine it is the water pump now why do you have oil coming out of it should be coolant . scratch
m1n1ster
m1n1ster
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSun Apr 28, 2013 10:44 pm
The water pump is further back, this is the most forward part of the engine at the bottom. I have a 700 which may be different then the 660. I'm pretty sure it is the crankcase halves which according to James is sealed with yamabond. Guess the question now is do I have the guts to tear into it myself. I have the service manual but was wondering about any special tools, should I go ahead and change all bearings, new oil seals, piston rings? Figure if I have to go in may as well do it all. Also was wondering about upgrading does it give you any advantage on the trail or are the upgrades mainly for speed?
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeMon Apr 29, 2013 12:33 am
the billet middle gear support is a must if you go in to it , just to get the pot metal (aluminum) shit out . me I believe don't leave anything to chance if you think it could be or go bad replace it while your there, also I love the part of go fast so you know my thoughts of mods
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeTue Apr 30, 2013 9:15 pm
welcome get er done
EddieMc
EddieMc
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeWed May 01, 2013 2:22 pm
welcome once u get to the roo of your problem theres info on mods on here or ask the fellas
bubba53
bubba53
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeFri May 03, 2013 8:16 am
Welcome to the fun
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeFri May 03, 2013 10:35 am
just wonder what ya found on the oil leak
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeTue May 07, 2013 9:18 pm
Welcome.
m1n1ster
m1n1ster
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeFri May 10, 2013 7:33 pm
Got all the parts from James to start, no mods other than reverse gear upgrade. Suppose to be 10 to 12 hours. I'll let you know how it goes, considering this is my first time in one of these engines.
m1n1ster
m1n1ster
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSun May 12, 2013 9:50 am
So here is where I got to, the AC magneto rotor. I was using a puller but it seemed to have a lot more resistance than I would think. Is this normal, or is there something else I must remove to get it off?
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeSun May 12, 2013 9:53 am
they are like that..
m1n1ster
m1n1ster
PostSubject: Re: New from Newport, TN   New from Newport, TN Icon_minitimeWed May 15, 2013 11:15 am
Finally, got all the stuff, bolts out of the way. Any advice on getting cases apart?
HOTRODRHINOFORUMS.COM :: Members :: New Members-
