Bumpers
| Subject: Oil cooler upgrade? Sat May 04, 2013 2:23 pm | |
| Has anyone upgraded oil coolers and moved them? Mine has had its better days and the fins are all bent up from pressure washing and the sort. I was thinking of moving it or maybe getting on the ones with a small fan on it.. I know with the fins being jacked up and stuff its blocking a lot of airflow to the rad and also the hot air off the oil cooler is flowing through the rad itself. What say ye? anyone done this? | |
| Subject: Re: Oil cooler upgrade? Sat May 04, 2013 2:51 pm | |
Bumpers
| Subject: Re: Oil cooler upgrade? Sun May 05, 2013 1:55 am | |
| I seen tha .. I like it .. how did it effec the engine temps? Did it drop it much or about the same ? | |
| Subject: Re: Oil cooler upgrade? Fri May 10, 2013 6:57 am | |
| I have not done it , but I would like to in the future mods never stop , but you would think when you move the oil cooler that it would help the radiator run a little cooler just from more air flow P.S. Steve's looks great | |
| Subject: Re: Oil cooler upgrade? Fri May 10, 2013 11:23 am | |
| Plus with twice as much fluid would it have more time to cool before it goes back into the motor or is this just a theory? | |
| Subject: Re: Oil cooler upgrade? Fri May 10, 2013 1:32 pm | |
| - CustomizedRhino13 wrote:
- Plus with twice as much fluid would it have more time to cool before it goes back into the motor or is this just a theory?
x2 anytime you can increase the volume of your cooling fluid you will make it cool more efficiently. (this is a setup for steve s.) | |
| Subject: Re: Oil cooler upgrade? | |
