| a/f mixture screw and pilot jet | |
jaydog13
| Subject: a/f mixture screw and pilot jet Wed May 01, 2013 5:05 pm | |
| recently done a little motor work to the ol rhino, also got my a/f gauge installed. I started it up and it was idling like shit and the a/f gauge read 18.9 so i back the a/f screw out to get it right, AND to get it right i had to back it out 7.5 turns just to get the gauge to read 14. So now my question is with a 45 pilot jet in the carb now and 7.5 out on the screw. should i try to go up just one jet size or do u think i should go with 2 sizes up. the only pilot jets i have available are 45,50,55,60,65 i dont have any half jet sizes. Thanks | |
| Subject: Re: a/f mixture screw and pilot jet Wed May 01, 2013 5:47 pm | |
| Jason, I'm no expert but 7.5 turns out seems turned out quite a bit. Probably something else is causing the problem. | |
| Subject: Re: a/f mixture screw and pilot jet Wed May 01, 2013 6:32 pm | |
| mine has a 55 in it may try that see if it helps | |
jaydog13
| Subject: Re: a/f mixture screw and pilot jet Wed May 01, 2013 6:43 pm | |
| From what i gathered over the last few weeks is that. A/f screw and pilot both have effect on idle. Kinda like every jet in the Carb does not work solo. Hope this makes since. And please let me know if I'm wrong. (a/f+pilot=idle and bottom) pilot+needle= bottom and mid (needle + main= mid and top) then main is wtfo. This may be wrong. But that's why I think I need a bigger pilot. | |
| Subject: Re: a/f mixture screw and pilot jet Wed May 01, 2013 7:37 pm | |
| Subject: Re: a/f mixture screw and pilot jet Thu May 02, 2013 11:04 am | |
| x2 very good break down on it , now if I could remember when mine is screwing up that would be great , maybe too many hikes in my past | |
| Subject: Re: a/f mixture screw and pilot jet Thu May 02, 2013 11:28 pm | |
| The A/F mixture screw only operates to 3 full turns, It is wide open after 3 turns. You need to go up on your pilot jet to atleast 50, The screw is for fine tuning only. | |
| Subject: Re: a/f mixture screw and pilot jet Fri May 03, 2013 12:57 am | |
| Mike on your 05 what pilot are you running I got the 55 just wonder if its enough when I 'm tuning tomorrow I will figure out just trying to save a little time, thanks Mike | |
| Subject: Re: a/f mixture screw and pilot jet Fri May 03, 2013 11:25 am | |
| It's been awhile since I looked at it but 55-60 sounds right. | |
| Subject: Re: a/f mixture screw and pilot jet | |
