In total there are 37 users online :: 0 Registered, 0 Hidden and 37 Guests :: 1 Bot
660 head Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
660 head Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
660 head Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
660 head Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
660 head Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
660 head Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
660 head Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
660 head Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
660 head Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
660 head Vote_lcap660 head Voting_bar660 head Vote_rcap
 660 head
4 posters
RADICAL RAM
660 head Empty
PostSubject: 660 head   660 head Icon_minitimeSun May 05, 2013 4:41 pm
I am in process of rebuilding my 660.
where the cam rides on the head and valve cover is no longer polished shiny and smooth like I think it should be. same goes for my cam not longer polished shiny and smooth. if i re-use this head i will likely buy a new cam to run in it it if that will make a difference.
Is this OK to re-install or should i find another head that has polished and shiny surfaces
thanks for any advice or suggestions
660 head Empty
PostSubject: Re: 660 head   660 head Icon_minitimeSun May 05, 2013 4:58 pm
I would think rework yours or replace
ALBANATE
660 head Empty
PostSubject: Re: 660 head   660 head Icon_minitimeWed May 15, 2013 7:20 pm
Can you snap a few pictures and post them up? Since there are no cam bearings and the surfaces are matched to the cam cap/cover it can be a problem. If you can feel the scratches with your finger it is likely bad. Unfortunately since the back side of the cam is a blind hole you can not line bore all the way through like you can on some heads.
Nate
Alba Racing
RADICAL RAM
660 head Empty
PostSubject: Re: 660 head   660 head Icon_minitimeThu May 16, 2013 8:45 am
Nate
Alba Racing
Nate, there are not any scratches, you cannot feel anything not even a lip or high spot where anything is worn down. it just looks like you went over it with very fine sandpaper (metal shavings from wet clutch) and dulled the polished finish. What do you think?? I was planning to re-use it with a new cam.
thanks
Kyle
660 head Empty
PostSubject: Re: 660 head   660 head Icon_minitimeThu May 16, 2013 9:07 am
I had the same problem with my wet clutch so I'm waiting to see what nate says. I know i need new valve seals so when i am putting them in I might put a new cam in
http://www.trailbrightled.com
ALBANATE
660 head Empty
PostSubject: Re: 660 head   660 head Icon_minitimeThu May 16, 2013 1:16 pm
You can use some fine scotchbrite to clean it up a bit. When using the scotchbrite only make passes in the direction of rotation.
Nate
Alba Racing
660 head Empty
660 head
» Engine pics
» 660 head and cam
» head rest bar
» How do you secure the muffler head pipe seal?
» Head install
