In total there are 33 users online :: 0 Registered, 0 Hidden and 33 Guests :: 1 Bot
Rt front tire turned out Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Rt front tire turned out Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Rt front tire turned out Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Rt front tire turned out Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Rt front tire turned out Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Rt front tire turned out Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Rt front tire turned out Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Rt front tire turned out Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Rt front tire turned out Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Rt front tire turned out Vote_lcapRt front tire turned out Voting_barRt front tire turned out Vote_rcap
5 posters
Brian lee Rhino450
Brian lee Rhino450
Rt front tire turned out Empty
PostSubject: Rt front tire turned out   Rt front tire turned out Icon_minitimeSun May 05, 2013 11:24 pm
Not sure if im putting this in the right section but here goes. Flip my rhino on pass side, rt front tire dug in and on its side it went. I have seen James alignment vid already. When i look down the left side front wheel is straight, when i look down rt side wheel is turned out. Can i bring that rt side back in using the tierod or is it best to keep both rods the same. Or did i possably damage something eveything looks straight except the wheel also nothing is loose. Could use some advise before i just adjust one side
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeSun May 05, 2013 11:41 pm
Rt front tire turned out Toe-in10
see if this helps
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeSun May 05, 2013 11:49 pm
Thanks, i have a manual this is not toe in or out, the wheel is turned to the rt while the left wheel is straight
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeMon May 06, 2013 12:21 am
an the tie rod is in place , not broke ? have you taken tire off ,how does knuckle look. also look at the rack & pinion
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeMon May 06, 2013 1:05 am
Tierods in place not broken. Steering works, knuckle looks fine, ill take wheel off tomarrow. Thanks
Workhorserhino
Workhorserhino
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeMon May 06, 2013 5:46 am
Your steering arm probably bent. Known to be very weak. Compare to left, you'll probably find it to be bent up or closer to tire.
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeMon May 06, 2013 7:03 am
i will check that this morn when i get off work thanks. Is that also known as the spindle?
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeMon May 06, 2013 7:26 am
[quote="Brian lee Rhino450"]
i will check that this morn when i get off work thanks. Is that what hooks up to the back of the spindle?
Workhorserhino
Workhorserhino
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeMon May 06, 2013 9:39 pm
You would be correct. I put mine on its left side twice in the first year. the arm bent, but I could adjust it out. I did the right side last year on a tree. I could adjust it out some, but the thread got a little thin. I put a new knuckle in this year and straightened it all out. As a redneck guide, 1/2 inch or less of threads in outer tie rod would be bad.
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeMon May 06, 2013 11:05 pm
I think i follow u r u saying u just adjusted 1 tierod to line it up. Cause i took it apart today and nothinh looked obviously bent. May pull out the rack and pinion and take a look, but per the manual it checks good. I had always heard that if u adjust one tierod u should keep both sides the same. Thanks for ur help
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeTue May 07, 2013 12:10 am
yep...bent spindle
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeTue May 07, 2013 12:19 am
WV Hot Rod Rhino wrote:
yep...bent spindle
James do u have those in stock if so ill b calling u tomarrow afternoon. Might as well get both sides. Mine is an 09 450
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeTue May 07, 2013 12:22 am
i do...
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeTue May 07, 2013 12:26 am
What will both cost me and what else will i need to go with them. Ball joints? Seals? Bearings? Let me know will call u about 2pm tomarrow
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeTue May 07, 2013 12:38 am
comes with seals,bearings and one balljoint...310 for both shipped
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeTue May 07, 2013 12:42 am
Thanks James. Talk to ya tomarrow
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: Rt front tire turned out   Rt front tire turned out Icon_minitimeWed May 15, 2013 3:05 pm
Got my parts yesterday James, its all back together and straight as an arrow. Steering feels much better also. Thanks for your help
» Tire Rub
» Trying New tire
» Best tire deals
» Tire size?
» atv tire weight chart
