In total there are 11 users online :: 0 Registered, 0 Hidden and 11 Guests :: 3 Bots
Open air box ok? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Open air box ok? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Open air box ok? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Open air box ok? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Open air box ok? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Open air box ok? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Open air box ok? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Open air box ok? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Open air box ok? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Open air box ok? Vote_lcapOpen air box ok? Voting_barOpen air box ok? Vote_rcap
 Open air box ok?
2 posters
AZredrhino
AZredrhino
Open air box ok? Empty
PostSubject: Open air box ok?   Open air box ok? Icon_minitimeMon May 06, 2013 4:26 am
So I'm trying the options for less noise on my ride. I removed the factory snorkel put a screen over the air box inlet, stuffed the hole in the motor box and taped it up. Is it ok to let it take in the air right in the motor box? I thought I'd try this before going full snorkel to the front and dealing with possible re-jetting which I know nothing about.
Other sound mods.
lined motor box with 250 degree reflective wrap. Hope motor don't get to hot
I used spray adhesive and put thick carpet padding on bed front behind seats
I ran more carpet padding under both seats. I made sure it didn't get close to anything that gets hot.
I have only did a run down the street so don't know full affect yet.
at idle it's much quieter but when I open it up I wasn't that impressed but we'll see
seems nothing can tame the roar when going fast.
PostSubject: Re: Open air box ok?   Open air box ok? Icon_minitimeMon May 06, 2013 9:56 am
just will be hot air going in would be better to get the cooler air , will also make your filter get dirty much faster. the other thing is be careful around water don't want to swamp your air box . the snorkel will help with the noise in cab
Open air box ok?
» Uwharrie is open for riding
