In total there are 26 users online :: 0 Registered, 0 Hidden and 26 Guests :: 2 Bots
Alba Rhino700 T-body bore special Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Alba Rhino700 T-body bore special Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Alba Rhino700 T-body bore special Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Alba Rhino700 T-body bore special Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Alba Rhino700 T-body bore special Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Alba Rhino700 T-body bore special Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Alba Rhino700 T-body bore special Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Alba Rhino700 T-body bore special Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Alba Rhino700 T-body bore special Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Alba Rhino700 T-body bore special Vote_lcapAlba Rhino700 T-body bore special Voting_barAlba Rhino700 T-body bore special Vote_rcap
3 posters
ALBANATE
Alba Rhino700 T-body bore special Empty
PostSubject: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 5:12 pm
Well I kinda left the 700 guys out, so to show some love we will bore a Rhino700 t-body with butterfly for $160 for forum members...
[img]Alba Rhino700 T-body bore special Web_pi11[/img]
Nate
Alba Racing
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 6:18 pm
Not trying to hi-jack just have a quik question for you can you tell me a little about the hd 50/50 cam.
ALBANATE
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 6:24 pm
I am sorry,but I can not. I do not use HDD cams. I ONLY use Web camshafts...
Nate
Alba Racing
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 6:31 pm
Ok thanks could you tell me what you thank would be the best cam for my set up I have one of your heads on my motor and it is awsome by the way. I am looking for low to mid range power.
ALBANATE
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 6:39 pm
One of our heads? With +2mm valves???...not likely. If you want to retain as much power on the front side and mid as possible you shouldn't go to big on the cam. Especially with +2mm valves. I would not go bigger than Web's 40c/942 profile. If you want to get the most out of that build that you have I would run the 290 cam and just make sure your clutch is spot on...
Nate
Alba Racing
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 6:42 pm
he has racers edge...i need a cam for the same thing to try...
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 6:46 pm
Ohh shit sorry but thanks for the advice.
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 6:48 pm
get you one teddy...i will put it in
ALBANATE
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 6:53 pm
Do you want me to send both out to you James and you can see whatcha think?
Nate
Alba Racing
ALBANATE
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 6:55 pm
BTW James, Web just called and the little guy we were discussing is shipping today!
Nate
Alba Racing
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 7:14 pm
How much.
ALBANATE
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 7:21 pm
We can do $190 with your stock cam in exchange on Web cams for forum members...
Nate
Alba Racing
PostSubject: Re: Alba Rhino700 T-body bore special   Alba Rhino700 T-body bore special Icon_minitimeThu May 16, 2013 9:01 pm
yep...send both..thanks
» ALBA 734 Big Bore for 2011 Rhino 700
» Throttle body spacer
» How big to bore TB?
» 700 Rhino throttle body problems
» 660 CARB BORING SPECIAL
