Who is online? | In total there are 42 users online :: 0 Registered, 0 Hidden and 42 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | Amp in glove box, and speaker wiring??'s | |
kris55
Posts : 46 Join date : 2013-03-15 Age : 46 Location : Iron Range area, MN
| Subject: Amp in glove box, and speaker wiring??'s Sat May 18, 2013 1:06 pm | |
| I picked up the Pyle 4 channel 100 w amp with ipod/mp3 plug in and would like to mount it in the glove box. Is there anything special I should do to waterproof the glove box, silicone or those little hole plugs for any holes I have to make for wiring?
How about mounting the amp, just screw it to bottom of glove box and call it good, or use a type of backing plate maybe, or similar?
Now to speaker wiring, first do I need to silicone the terminals on the speaker once the wires are attached? they are marine speakers. Can I drill holes in roll bar to hide wires inside it?
If there's any other tips or tricks you guys might find helpful for hooking up the amp and speakers please tell, I'm a complete novice on this stuff.
Thanks!! | |
| | | T.Rhino
| Subject: Re: Amp in glove box, and speaker wiring??'s Sat May 18, 2013 1:18 pm | |
| The amp itself is waterproof but I did silicone the holes I drilled in the glove box to the wires threw. And I ran my wires out of the side of the glove box and up the roll cage by using mig wire from my welder worked really well. And silicone never hurts on the wiring alot of bouncing going on shrink tube works good too. | |
| | | RHINOMOON
| Subject: Re: Amp in glove box, and speaker wiring??'s Thu May 23, 2013 10:10 pm | |
| mine is under my roof. cut 2 pices of plywood and jam them between top rollbars screw them in the corners and now you have a nice mounting spot for your things that shouldn get wet. | |
| | | kris55
| Subject: Re: Amp in glove box, and speaker wiring??'s Fri May 24, 2013 8:23 am | |
| Finished it up yesterday, amp is in glovebox. I'll try to take pics after this weekend and post them up. | |
| | | banchee6
| Subject: Re: Amp in glove box, and speaker wiring??'s Fri May 24, 2013 10:51 am | |
| As long as you don't put the glove box underwater, you should be good. Seal all the exterior holes and keep it closed. Yea, post some pics for other that wanna do the same thing. Everyone loves pics. | |
| | | kris55
| Subject: Re: Amp in glove box, and speaker wiring??'s Fri May 24, 2013 12:39 pm | |
| - banchee6 wrote:
- As long as you don't put the glove box underwater, you should be good. Seal all the exterior holes and keep it closed. Yea, post some pics for other that wanna do the same thing. Everyone loves pics.
I hope it doesn't go underwater! lol. I did seal all the holes with silicone in the glove box area. I will try to get pics posted, prob on Mon., or tues., if I can figure out how. | |
| | | kris55
| Subject: Re: Amp in glove box, and speaker wiring??'s Tue May 28, 2013 9:00 am | |
I will try to get pics posted, prob on Mon., or tues., if I can figure out how. Well, Thanks banchee6, I think you jinxed me this weekend, might need to drill a small hole in glove box now to drain water that may get in. [img] [/img] | |
| | | UnderDawg
| Subject: Re: Amp in glove box, and speaker wiring??'s Tue May 28, 2013 9:29 am | |
| my amp is under the seat in a ammo can its been under water a few times and has stayed nice and dry...so far! | |
| | | WV Hot Rod Rhino Admin
| Subject: Re: Amp in glove box, and speaker wiring??'s Tue May 28, 2013 11:05 am | |
| mine is on top of the glove box under the hood | |
| | | banchee6
| Subject: Re: Amp in glove box, and speaker wiring??'s Tue May 28, 2013 11:42 am | |
| Damn!!! I'm sorry for that. That's why I don't lead anymore. Lmao. | |
| Subject: Re: Amp in glove box, and speaker wiring??'s | |
