| Fuse Block with Relay | |
lost|concept
| Subject: Fuse Block with Relay Sun Apr 28, 2013 6:32 pm | |
| I see these fuse blocks with relays advertised everywhere for rhino accessories. Are these things worth it and are they needed even? | |
| Subject: Re: Fuse Block with Relay Sun Apr 28, 2013 7:26 pm | |
| I liked the wright up Chris did on the accessory wiring an yes I think the fuse block is the way to go , been looking into marine ones to do mine | |
| Subject: Re: Fuse Block with Relay Sun Apr 28, 2013 8:04 pm | |
lost|concept
| Subject: Re: Fuse Block with Relay Sun Apr 28, 2013 8:10 pm | |
| So do you recommend the use of a second battery as well? Or not needed unless pulling major amps? | |
| Subject: Re: Fuse Block with Relay Sun Apr 28, 2013 8:15 pm | |
| - lost|concept wrote:
- So do you recommend the use of a second battery as well? Or not needed unless pulling major amps?
What is your amp draw? If your running a stereo and amp and a bunch of lights ,yes. If not that much of a draw no. It just depends on your power needs. I'm only running a single battery, it's an Odyssey PC 925. | |
lost|concept
| Subject: Re: Fuse Block with Relay Sun Apr 28, 2013 8:16 pm | |
| - rhino727 wrote:
- I liked the wright up Chris did on the accessory wiring an yes I think the fuse block is the way to go , been looking into marine ones to do mine
Where can I find this write up? | |
| Subject: Re: Fuse Block with Relay Sun Apr 28, 2013 9:02 pm | |
| look up( putting in gauges) under lighting , stereo , and electrical Chris talks about the fuse block | |
lost|concept
| Subject: Re: Fuse Block with Relay Tue Apr 30, 2013 11:56 pm | |
| Thanks for the info. Ordered one on Sunday. Should be in tomorrow morning... | |
| Subject: Re: Fuse Block with Relay Sat May 04, 2013 3:30 am | |
| cool tell how it turns out | |
soarkrebel
| Subject: Re: Fuse Block with Relay Mon May 13, 2013 2:26 pm | |
| I am looking at the painless or something like it to add some things. It's the smart way to go. | |
| Subject: Re: Fuse Block with Relay Tue May 14, 2013 12:46 pm | |
| check out the blue sea marine fuse blocks seem nice at less than half the price of the painless if your interested I know painless makes great stuff though | |
brianak
Posts : 58 Join date : 2013-03-26 Location : Anchorage, AK
| Subject: Re: Fuse Block with Relay Tue May 14, 2013 2:05 pm | |
| That's the one I used. Just have to wire in a relay. | |
| Subject: Re: Fuse Block with Relay | |
