In total there are 16 users online :: 0 Registered, 0 Hidden and 16 Guests :: 2 Bots
clutch spring suggestion Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
clutch spring suggestion Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
clutch spring suggestion Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
clutch spring suggestion Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
clutch spring suggestion Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
clutch spring suggestion Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
clutch spring suggestion Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
clutch spring suggestion Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
clutch spring suggestion Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
clutch spring suggestion Vote_lcapclutch spring suggestion Voting_barclutch spring suggestion Vote_rcap
doober
9 posters
Go to page : 1, 2  Next
doober
clutch spring suggestion Empty
PostSubject: clutch spring suggestion   clutch spring suggestion Icon_minitimeTue May 21, 2013 1:56 pm
I have an 08 700. JBS sheeve, 18g od weights, 26" zillas and other than that it is stock, Thinking it might be time to replace the stock secondary spring (have 4500 miles) we ride mostly trails but also hit the mud, i would like to keep the top end about where it is (50 mph approx) or higher, but was wondering what spring would work best for my needs, i have read the EPI orange it close to stock, but the purple is a good choice also..just looking for some advice. thanks.
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeTue May 21, 2013 4:33 pm
I have the same machine with 25" ,I have a purple spring,47-48 on the dirt. You will need to add a cdi to reach 50MPH. Smile
doober
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeTue May 21, 2013 7:48 pm
Hows the bottom end now, any improvement or about the same?
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeTue May 21, 2013 8:08 pm
I feel that the trans has a slightly lower gear and I really feel the engine brake more at low speed I mean off idle,and I feel mid range power is slightly better.
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeWed May 22, 2013 4:14 am
James was thinking of changing my purple back to stock when he built my rhino. (his 1st 2012 build) I was screaming NO after riding it. Even if it would give me 2mph, there is no way I would switch back. This thing is a bad mofo when you get back in the gas, and on a nasty hill in high range. On the dirt roads I feel like it's reving more than I like, but when I slam the throttle down, I know to leave this thing alone.
I told him I wanted it clutched to be fast on the trails and that's what I got. clutch spring suggestion 2016508534
doober
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeWed May 22, 2013 11:47 am
so it sounds like i would be pretty happy with the purple spring instead of the orange then?
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeThu May 23, 2013 3:27 am
I think the orange is more agressive than the purple. Seems like the purple is one step up from the stock spring. I could be wrong though. Weights change things alot, but I know the purple does really well with tall 25s and 26" tires with heavier aftermarket wheels. It seems to me that changing the spring is like changing gears in the rearend of a car, and the weights are like changing converters in a auto trans in a car.
doober
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeThu May 23, 2013 1:45 pm
I have 26" zillas 9 on front 11 on back, stock rims
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 1:07 am
I think you will like the purple. I'm not the best one to give advice on this because I only drove mine all stock with stock tires, then with cam, 18s, and the stock spring. When James got my cdi in, he put the 16s and purple spring in. I can't compare it to another because of the other things that we changed, but it runs strong up hills and out of the corners. I would never want anything more agressive, but like I said, I'm running 16s so it revs quick.
I'm running 25" bighorns, they measure a true 25-25 1/4" tall depending on psi. I'm on the stock sport wheels.
doober
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 12:00 pm
By aggressive do you mean it revs high before engaging?
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 12:02 pm
purple is 1 step heavier...you will like it
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 2:13 pm
so explain purple vs gold spring
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 2:38 pm
if i understand it correctly,
stronger springs (gold) slow the upshift (higher rpm) and improve the backshift.
softer springs (purple) increase the upshift (lower rpm) and slow the backshift.
it fine tunes according to the way you ride...
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 2:42 pm
correct...if he has orange and goes to purple he will have higher rpms and quicker backshift...great for trails not for open road
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 2:49 pm
the weights for the springs are
red 160/250
blue 160/280
orange 190/310
purple 195/315
gold 200/330
white 215/350
if this helps
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 4:57 pm
i know it's off topic, but i've been looking at the way polaris clutches work.
holy shit! there are an awful lot of parts to maintain on theirs. the yamaha is 10x easier to maintain & service bounce
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 5:29 pm
i did a clutch on my buddies rzr, was not bad, they have a real nice helix with anti friction washers. his clutch kit from Holz racing was almost $500...ouch
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 6:14 pm
Why is it different for 660's and 700's as far as weights and springs?
doober
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 8:51 pm
I have stock right now james, your sheeve Smile 26" zillas, ride a lot of trails, hills, and some mud, will the purple scream at me?
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 8:54 pm
do you have a cdi?
doober
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeFri May 24, 2013 10:24 pm
do you have a cdi?
No cdi, basically stock besides your sheeve 18g od weights, and 26" zillas
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeSat May 25, 2013 1:27 am
My setup does rev hard out on the roads. On the bigger gravel/dirt roads cruising 40mph, it is reving much harder than it needs to in order to maintain speed. I don't like that much. BUT, when I hit the trails, mud, and hills that these things were meant to run, holly crap do I love it! I thought about going to 18g weights, but after shoving a rzr s through the woods, there is no way I'm changing a thing. clutch spring suggestion 2016508534clutch spring suggestion 2016508534clutch spring suggestion 2016508534clutch spring suggestion 2016508534
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeSat May 25, 2013 8:20 am
do you have a cdi?
your limited to what you can run without a cdi
doober
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeSat May 25, 2013 11:53 am
Think im sold on the purple now, sounds like it would bring the revs up to where they were before the sheeve approx? At cruising speed the way it is now, the revs are lower than stock.
PostSubject: Re: clutch spring suggestion   clutch spring suggestion Icon_minitimeSat May 25, 2013 12:24 pm
red 160/250
blue 160/280
orange 190/310
purple 195/315
gold 200/330
white 215/350
if this helps
I didn't know they had a white spring you don't here much about it or many people using it.
» What secondery spring to use
» which spring
» how u know your spring is worn out
» Secondary spring removal?
» spring washers?
