| grrrrrr | |
+5WV Hot Rod Rhino rhino727 CUSTOMIZEDRHINO13 flimmy dome.us 9 posters |
dome.us
Posts : 23 Join date : 2013-05-20 Age : 41 Location : northern utah
| Subject: grrrrrr Tue May 28, 2013 10:55 pm | |
| so my rhino has bern sittin for two days, today iI go to move it and it won't start. it has spark and as far as iI can tell it is getting gas. cranks over good and backfires but no start any help? | |
dome.us
| Subject: Re: grrrrrr Tue May 28, 2013 11:05 pm | |
| Subject: Re: grrrrrr Tue May 28, 2013 11:18 pm | |
| It may have lost its prime. I put a prime bulb on mine and when it sits for a few days i just pump out and it starts right up | |
dome.us
| Subject: Re: grrrrrr Tue May 28, 2013 11:24 pm | |
| its never had this prob i can see gas half way up the filter and can pull the line off the carb and gas runs out.. | |
| Subject: Re: grrrrrr Wed May 29, 2013 12:35 am | |
dome.us
| Subject: Re: grrrrrr Wed May 29, 2013 1:22 am | |
| Subject: Re: grrrrrr Wed May 29, 2013 2:04 am | |
| Check your tank for any gunk floating around the bottom, make sure your fuel pickup isn't cracked( I broke mine when I was installing the seats and didn't know till later. You could try pressurizing the tank through the vent line with an air compressor(just a enough to push some fuel and not blow anything) to see if your pump is bad. Hope this helps ya out, nothing worse than not knowing your problem. | |
dome.us
| Subject: Re: grrrrrr Wed May 29, 2013 2:25 am | |
| iI pulled the outlet hose off the pump and it seemed to be pumping..it sucks its been a bad month for the rhino iI just fix something then something else breaks. this time iI have no idea what or how to fix it. thanks | |
| Subject: Re: grrrrrr Wed May 29, 2013 8:44 am | |
| something else with you saying it backfires , more than just getting fuel to it . plug ,timing, valves settings------flooding if raw gas is in pipe could do it to, just my thoughts good luck | |
| Subject: Re: grrrrrr Wed May 29, 2013 8:58 am | |
| if it has fire and gas check the flywheel key to see if it sheared.... | |
| Subject: Re: grrrrrr Wed May 29, 2013 9:33 am | |
| Have u cheaked the air filter ? | |
| Subject: Re: grrrrrr Wed May 29, 2013 9:43 am | |
dome.us
| Subject: Re: grrrrrr Wed May 29, 2013 10:11 am | |
| iI had the filter off for a second still wont do anything. I'm not sure how to check the flywheel. i will lopk into that after work | |
| Subject: Re: grrrrrr Wed May 29, 2013 10:35 am | |
| get it up on tdc with a straw then see if the timing marks line up | |
dome.us
| Subject: Re: grrrrrr Wed May 29, 2013 11:46 am | |
| if it has spark wouldnt the fly wheel be good? | |
| Subject: Re: grrrrrr Wed May 29, 2013 11:55 am | |
| firing at the wrong time...fix them like that alot | |
dome.us
| Subject: Re: grrrrrr Wed May 29, 2013 12:23 pm | |
| what causes it to do that? sorry im full of questions.. th nks for the info | |
thekrust
| Subject: Re: grrrrrr Wed May 29, 2013 4:39 pm | |
| Before you dig too far put in a new spark plug. I see this alot too...will spark outside the engine but when you put it in it will backfire and not run just as described. If this doesn;t fix it dig deeper. | |
dome.us
| Subject: Re: grrrrrr Wed May 29, 2013 10:35 pm | |
| checked the air filter, spark, changed plug, seems to be getting gas stills just turns over. the flywheel and timing check is out of my skills I think... it might be time to haul her to the stealer and let them pillage my village and wait two weeks | |
dome.us
| Subject: Re: grrrrrr Wed May 29, 2013 11:10 pm | |
| iI pulled the air filter off one more time and put my hand over it to see if it was sucking it was and blowin my hand was covered with gas after a couple of cranks is this normal | |
| Subject: Re: grrrrrr Wed May 29, 2013 11:14 pm | |
| intake valves need adjusted or the fly wheel key...call me tomorrow and i will guide you through it...you can do it | |
dome.us
| Subject: Re: grrrrrr Wed May 29, 2013 11:34 pm | |
| Subject: Re: grrrrrr Thu May 30, 2013 6:59 am | |
| James to the rescue again! Hes a good man. | |
| Subject: Re: grrrrrr Thu May 30, 2013 9:42 am | |
| YOU CAN DO IT!!!! AN James will help ya just can't beat the service from him | |
dome.us
| Subject: Re: grrrrrr Sat Jun 01, 2013 2:21 am | |
| Its alive!!! Thanks to james! I checked my flywheel seemeed good so I adjusted my valves they were tight as shit! Got her back together it started right up made alittle clank noise but smoothed out and sounds good...i would have never thought my retarded ass could do it thanks everyone... I'lll take it out tomorrow for a test ride. | |
| Subject: Re: grrrrrr | |
| grrrrrr | |
