In total there are 14 users online :: 0 Registered, 0 Hidden and 14 Guests :: 2 Bots
Removing the fan next to gas tank on my 660?'s Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Removing the fan next to gas tank on my 660?'s Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Removing the fan next to gas tank on my 660?'s Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Removing the fan next to gas tank on my 660?'s Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Removing the fan next to gas tank on my 660?'s Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Removing the fan next to gas tank on my 660?'s Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Removing the fan next to gas tank on my 660?'s Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Removing the fan next to gas tank on my 660?'s Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Removing the fan next to gas tank on my 660?'s Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Removing the fan next to gas tank on my 660?'s Vote_lcapRemoving the fan next to gas tank on my 660?'s Voting_barRemoving the fan next to gas tank on my 660?'s Vote_rcap
Execelon
kris55
6 posters
kris55
kris55
Removing the fan next to gas tank on my 660?'s Empty
PostSubject: Removing the fan next to gas tank on my 660?'s   Removing the fan next to gas tank on my 660?'s Icon_minitimeWed May 29, 2013 10:16 am
Ok so I am sick of that fan always being plugged with debris and getting the ducting knocked off behind the seat, so I want to remove it.
So what exactly do I need to remove to get rid of it? everything associated with the fan? or just the impeller itself?
Also how about the ducting for it, can I get rid of that also?
Thanks!
Execelon
PostSubject: Re: Removing the fan next to gas tank on my 660?'s   Removing the fan next to gas tank on my 660?'s Icon_minitimeWed May 29, 2013 10:32 am
Took me about 10minutes to take mine off, from what I've read it's suppose to keep the exhaust bracket cool. So far I haven't noticed any side effects.
kris55
kris55
PostSubject: Re: Removing the fan next to gas tank on my 660?'s   Removing the fan next to gas tank on my 660?'s Icon_minitimeWed May 29, 2013 10:39 am
So what parts exactly did u take off, the whole fan housing on that side? Or just the fan blade itself?
Did you leave any of the duct work to it in tact still?
Execelon
PostSubject: Re: Removing the fan next to gas tank on my 660?'s   Removing the fan next to gas tank on my 660?'s Icon_minitimeWed May 29, 2013 10:51 am
The housing, fan and hose.. You could install the housing back on as there is moving parts just hanging out down there, But theres nothing around to get caught up in it. I think the housing and fan had 4 bolts apiece my hose was just hanging out.
kris55
kris55
PostSubject: Re: Removing the fan next to gas tank on my 660?'s   Removing the fan next to gas tank on my 660?'s Icon_minitimeWed May 29, 2013 10:54 am
Awesome, Thanks!!
PostSubject: Re: Removing the fan next to gas tank on my 660?'s   Removing the fan next to gas tank on my 660?'s Icon_minitimeWed May 29, 2013 8:00 pm
FYI, you'll melt the rubber mount on your exhaust the first ride out and be dealing with a rattling exhaust. It's the one thing I wish I didn't do to my 660...I can't seem to get the friggin thing to not rattle loose every other trip.
thekrust
thekrust
PostSubject: Re: Removing the fan next to gas tank on my 660?'s   Removing the fan next to gas tank on my 660?'s Icon_minitimeThu May 30, 2013 12:35 pm
I had a similar problem, I made my own mount up front and added a second one at the rear of the muffler with a rubber pad under it. No more problems. It's worth not having that fan down there. I also took a gear lube bottle cut off and siliconed it to the side of the engine to cover up the rotating piece because I got a seal leak from junk getting wrapped in there.
PostSubject: Re: Removing the fan next to gas tank on my 660?'s   Removing the fan next to gas tank on my 660?'s Icon_minitimeThu May 30, 2013 12:42 pm
mine has been off for 5 years. i replaced the rubber hanger once. and i only removed the fan itself.
PostSubject: Re: Removing the fan next to gas tank on my 660?'s   Removing the fan next to gas tank on my 660?'s Icon_minitimeThu May 30, 2013 12:44 pm
x2 no problems
» removing wet clutch
» thinking of removing muzzys...
» gas tank
» need a 700 fuel tank
» BRP fuel tank kit for a 450
