In total there are 42 users online :: 0 Registered, 0 Hidden and 42 Guests :: 2 Bots
almost overheated. Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
almost overheated. Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
almost overheated. Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
almost overheated. Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
almost overheated. Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
almost overheated. Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
almost overheated. Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
almost overheated. Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
almost overheated. Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
almost overheated. Vote_lcapalmost overheated. Voting_baralmost overheated. Vote_rcap
 almost overheated.
brewis
Snorider
13 posters
almost overheated. Empty
PostSubject: almost overheated.   almost overheated. Icon_minitimeThu May 30, 2013 3:52 am
Just thought I would share this story. Don't forget to think for a minute, and check the little things if you have trouble.
I was riding alone Monday through a really tight trail deep in the woods in the middle of nowhere. Something caught my eye, it was my temp warning light. I shut it down and felt the engine cover, and it didn't seem to hot. Turned the switch on and raised the hood, and figured out the fan wasn't working. I looked it over good, and didn't see anything wrong. Pulled the fuse with the switch still in the on position, it was good. Put it back in and heard a clunk when it made connection, like the fan was hitting something. Reaching in where I couldn't really see, I found a stick the size of the tube in a ink pen. Pulled it out, pulled the fuse again, and re-installed...fixed. I can't believe that little thing kept the fan from starting. It somehow got up in there from the back side. Just thought I would share this so you know to look for the stupid stuff if your fan quits. I looked at it from all angles and didn't see it in there.
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeThu May 30, 2013 4:35 am
ya its the little turds that will bite you affraid
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeThu May 30, 2013 6:30 am
Just glad you found it when you did and not when you was tearing the motor down to repare it.
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeThu May 30, 2013 10:55 am
Glad you found it!! almost overheated. 2016508534
Snorider
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeThu May 30, 2013 6:04 pm
glad to hear you caught it in time. nice find
brewis
brewis
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeThu May 30, 2013 6:18 pm
Good eye, back in business.
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeThu May 30, 2013 6:24 pm
Thats good info right there !
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeFri May 31, 2013 12:06 am
Glad it was an easy fix. It pays to pay attention to the little things, like you said.
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeFri May 31, 2013 4:50 am
It really got me to thinking about how pathetic that idiot light really is, and how not noticing it can mean big problems. I was going slow in some real technical trails and got the thought in my head that something wasn't right, but I didn't know why at the time. I guess I was used to hearing the fan kicking on alot when going that slow. I didn't even realize that was what got me thinking until I seen the light. IDK how long the light was on, but I ran the hell out of it for 40 miles after that happend with no trouble. I guess I'm OK.
Never had that happen before. Only time I ever seen a temp light was due to a clogged radiator on a 650 prairie.
It's easy to get caught up in the fun and not check the guages enough. I need to run hard like Hot Rod so I get enough airflow that I don't even need a fan. lol!
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeFri May 31, 2013 8:42 am
shew...close call..glad you seen it
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeFri May 31, 2013 9:10 am
I'm a firm believer that everyone needs to install a temp gauge in these. That light is to damn small and easily not noticed.
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeFri May 31, 2013 9:25 pm
x 2...they outta b there from the factory !!
RiverRat
RiverRat
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeSat Jun 01, 2013 10:30 am
That coulda been bad. Crazy how a stick can cause so much trouble.
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeSun Jun 02, 2013 1:01 pm
I couldn't believe how small the limb was. It was about 3" long and not even 1/16" thick. Must have been wedged in there just right. I have never got anything caught in a fan like that till now.
I will have some guages in there soon.
PostSubject: Re: almost overheated.   almost overheated. Icon_minitimeSun Jun 02, 2013 9:17 pm
Thanks for the heads up...close call!!
almost overheated.
