| Not Enough Time in the Day | |
+4T.Rhino honda450sfm CUSTOMIZEDRHINO13 lost|concept 8 posters |
lost|concept
| Subject: Not Enough Time in the Day Fri May 31, 2013 12:04 am | |
| Well, I figured between working, farming, and tinkering in the garage I did not have enough to do. So I bought 40 acres with a house on it and a 50'x80' pole barn on it. In the next few months I have to put a new pump in the well, run a new water line from well to house, run a water line from house to shed, run gas, electric, and phone to shed, concrete shed floor, insulate shed and finish, dredge two ponds, and clear about 15,000 dead trees. Needless to say I may not be on as often as I would like to be in order to post. Also, the rhino building has had the e-brakes put on. I am really hoping that I can scrape up enough cash to at least get a set of doors and a sheave in it before winter. I will try to get some pictures posted once I close. | |
| Subject: Re: Not Enough Time in the Day Fri May 31, 2013 12:07 am | |
| Wow, you're a busy man to say the least! | |
lost|concept
| Subject: Re: Not Enough Time in the Day Fri May 31, 2013 12:15 am | |
| Yeah. Lucky for me I have access to heavy equipment for the cost of fuel only. But it is still over-whelming to say the least. | |
| Subject: Re: Not Enough Time in the Day Fri May 31, 2013 12:17 am | |
| Don't burn out with all that workload! Make time to ride a bit. | |
| Subject: Re: Not Enough Time in the Day Fri May 31, 2013 7:03 am | |
| Yes always leave time for riding. | |
| Subject: Re: Not Enough Time in the Day Fri May 31, 2013 8:44 am | |
| sounds like you gonna have a awesome place | |
JBFIREMAN
| Subject: Re: Not Enough Time in the Day Fri May 31, 2013 8:54 am | |
| With hard work comes great things | |
| Subject: Re: Not Enough Time in the Day Fri May 31, 2013 10:04 am | |
| damn i could only dream. 40 acres is hard to find where i live. and if you do find it it will cost you in the area of 1 million +. | |
Yotehunter66 Moderator
| Subject: Re: Not Enough Time in the Day Fri May 31, 2013 6:55 pm | |
| Thought I was working my arse off. Good luck. | |
| Subject: Re: Not Enough Time in the Day | |
