| almost overheated. | |
+9WV Hot Rod Rhino honda450sfm Firefighter brewis Snorider CUSTOMIZEDRHINO13 T.Rhino rhino727 Hump 13 posters |
| Subject: almost overheated. Thu May 30, 2013 3:52 am | |
| Just thought I would share this story. Don't forget to think for a minute, and check the little things if you have trouble.
I was riding alone Monday through a really tight trail deep in the woods in the middle of nowhere. Something caught my eye, it was my temp warning light. I shut it down and felt the engine cover, and it didn't seem to hot. Turned the switch on and raised the hood, and figured out the fan wasn't working. I looked it over good, and didn't see anything wrong. Pulled the fuse with the switch still in the on position, it was good. Put it back in and heard a clunk when it made connection, like the fan was hitting something. Reaching in where I couldn't really see, I found a stick the size of the tube in a ink pen. Pulled it out, pulled the fuse again, and re-installed...fixed. I can't believe that little thing kept the fan from starting. It somehow got up in there from the back side. Just thought I would share this so you know to look for the stupid stuff if your fan quits. I looked at it from all angles and didn't see it in there. | |
| Subject: Re: almost overheated. Thu May 30, 2013 4:35 am | |
| ya its the little turds that will bite you | |
| Subject: Re: almost overheated. Thu May 30, 2013 6:30 am | |
| Just glad you found it when you did and not when you was tearing the motor down to repare it. | |
| Subject: Re: almost overheated. Thu May 30, 2013 10:55 am | |
| Glad you found it!! | |
Snorider
| Subject: Re: almost overheated. Thu May 30, 2013 6:04 pm | |
| glad to hear you caught it in time. nice find | |
brewis
| Subject: Re: almost overheated. Thu May 30, 2013 6:18 pm | |
| Good eye, back in business. | |
| Subject: Re: almost overheated. Thu May 30, 2013 6:24 pm | |
| Thats good info right there ! | |
| Subject: Re: almost overheated. Fri May 31, 2013 12:06 am | |
| Glad it was an easy fix. It pays to pay attention to the little things, like you said. | |
| Subject: Re: almost overheated. Fri May 31, 2013 4:50 am | |
| It really got me to thinking about how pathetic that idiot light really is, and how not noticing it can mean big problems. I was going slow in some real technical trails and got the thought in my head that something wasn't right, but I didn't know why at the time. I guess I was used to hearing the fan kicking on alot when going that slow. I didn't even realize that was what got me thinking until I seen the light. IDK how long the light was on, but I ran the hell out of it for 40 miles after that happend with no trouble. I guess I'm OK. Never had that happen before. Only time I ever seen a temp light was due to a clogged radiator on a 650 prairie. It's easy to get caught up in the fun and not check the guages enough. I need to run hard like Hot Rod so I get enough airflow that I don't even need a fan. | |
| Subject: Re: almost overheated. Fri May 31, 2013 8:42 am | |
| shew...close call..glad you seen it | |
| Subject: Re: almost overheated. Fri May 31, 2013 9:10 am | |
| I'm a firm believer that everyone needs to install a temp gauge in these. That light is to damn small and easily not noticed. | |
| Subject: Re: almost overheated. Fri May 31, 2013 9:25 pm | |
| - Pokahpolice wrote:
- I'm a firm believer that everyone needs to install a temp gauge in these. That light is to damn small and easily not noticed.
x 2...they outta b there from the factory !! | |
RiverRat
| Subject: Re: almost overheated. Sat Jun 01, 2013 10:30 am | |
| That coulda been bad. Crazy how a stick can cause so much trouble. | |
| Subject: Re: almost overheated. Sun Jun 02, 2013 1:01 pm | |
| I couldn't believe how small the limb was. It was about 3" long and not even 1/16" thick. Must have been wedged in there just right. I have never got anything caught in a fan like that till now. I will have some guages in there soon. | |
| Subject: Re: almost overheated. Sun Jun 02, 2013 9:17 pm | |
| Thanks for the heads up...close call!! | |
| Subject: Re: almost overheated. | |
