Who is online? | In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests :: 1 Bot None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | 06' 660 will not crank | |
scottc
Posts : 2 Join date : 2013-06-04
| Subject: 06' 660 will not crank Tue Jun 04, 2013 1:46 pm | |
| I can’t seem to get my 06 rhino to crank. It will turn over but I have no fire at the spark plug. I’ve replaced the spark plug, stator, and CDI. I know the gear indicator switch isn’t working correctly also because I have to press the brake for it to engage the starter no matter if it’s in neutral or not. It was running fine when I parked it then it sat up for maybe a month and when I went back out to ride I couldn’t get it to crank. It’s been setting under my carport for close to a year now.. Any help would be much appreciated!.. | |
| | | WV Hot Rod Rhino Admin
| Subject: Re: 06' 660 will not crank Tue Jun 04, 2013 1:52 pm | |
| | | scottc
| Subject: Re: 06' 660 will not crank Tue Jun 04, 2013 1:55 pm | |
| I followed the service manual and did the Omh test on it and it seems to be fine.. | |
| | | CUSTOMIZEDRHINO13
| Subject: Re: 06' 660 will not crank Tue Jun 04, 2013 10:37 pm | |
| Check any wires for mice chewing something up. | |
| | | REDRHINO64
| Subject: Re: 06' 660 will not crank Tue Jun 04, 2013 10:54 pm | |
| Timing chain stretched,or jumped timing..intake valves too tight...adjust all valves,and check tdc on piston and timing marks on flywheel. | |
| | | REDRHINO64
| Subject: Re: 06' 660 will not crank Tue Jun 04, 2013 10:56 pm | |
| | | onebuilder
| Subject: Re: 06' 660 will not crank Fri Jun 07, 2013 1:19 am | |
| X2 on the mice damage. If it was running fine when you parked it, check inside the battery box. | |
| Subject: Re: 06' 660 will not crank | |
