| Subject: switch and harness Fri Jun 07, 2013 11:48 am | |
| do you have any switch kits in stock , do you think ill need a relay mick | |
| Subject: Re: switch and harness Fri Jun 07, 2013 11:54 am | |
| - madmax 1 wrote:
- do you have any switch kits in stock , do you think ill need a relay mick
Ummm, what'cha doing with a relay? If you want to raise them for fun and profit, you need to get two of them. | |
| Subject: Re: switch and harness Fri Jun 07, 2013 12:03 pm | |
| got a 40" DOUBLE ROW OFF OF flimmy not sure if it requires a relay | |
| Subject: Re: switch and harness Fri Jun 07, 2013 12:49 pm | |
| not enough draw to need a relay. just a heavy switch will do. | |
| Subject: Re: switch and harness Fri Jun 07, 2013 1:05 pm | |
| The 40" double row draws 17 amps. That's a little much for a reg switch. Unless you know the switch can handle 20 amps , I'd use a relay. The 30's draw 13 amps anything smaller is less then 10 and I would just run an inline fuse and the switch. | |
| Subject: Re: switch and harness | |
