| Nut on Secondary | |
+7PA. GRIZZLY scotearl scottwv wolverine34 ASPENDELLROVER Stuntmanmike 4x4ff 11 posters |
4x4ff
| Subject: Nut on Secondary Tue Jun 11, 2013 10:49 pm | |
| Well I am trying to get my secondary off to clean up my grease mess (See my other thread about chattering) and I can't get this damn thing to come loose. I don't know what the hell happened. I have used 2 electric impacts and air impact, torch (gotta be careful about melting the fan). You guys got any idea? I even had a friend who is a mechanic try....he said he has never seen anything like it. I has it off prior to my 'grease incident' and put it on normally. I did use an impact but not real hard.
Guess I'm gonna have to heat the crap out of it and buy a new fan. I'm open for suggestions.
Steve | |
| Subject: Re: Nut on Secondary Tue Jun 11, 2013 10:55 pm | |
| I have had to use a cold chisel to get them off if the impact gun wont do it. Buy a new nut. | |
| Subject: Re: Nut on Secondary Tue Jun 11, 2013 11:59 pm | |
| I had the same issue, even put 220psi of nitrogen on a 3/4 and nothing. so I cut the nut off with a dremel very carefully and got a new nut from James. I have had it off a couple times since with no issues. My thought is the nut fused with the cheap ass metal on the fan | |
wolverine34
Posts : 108 Join date : 2013-03-10 Age : 49 Location : Sourwood TN
| Subject: Re: Nut on Secondary Wed Jun 12, 2013 12:45 am | |
| i'm in the same boat. just melted some of my fan. and still no nut off. | |
| Subject: Re: Nut on Secondary Wed Jun 12, 2013 12:47 am | |
| its gotta be something with the 08. thats 3 on 1 thread. I had to buy a new fan too. | |
4x4ff
| Subject: Re: Nut on Secondary Wed Jun 12, 2013 1:04 am | |
| I've got an email into James for a price. Weird thing is it came off fine last time.
Steve | |
4x4ff
| Subject: Re: Nut on Secondary Wed Jun 12, 2013 1:10 am | |
| So....if I Dremel it off what is the best way to keep from buggering up the shaft?
Steve
| Subject: Re: Nut on Secondary Wed Jun 12, 2013 1:41 am | |
| I made 2 cuts just a pussy hair from the threads on the shaft then hit it with the impact and came right off | |
4x4ff
| Subject: Re: Nut on Secondary Wed Jun 12, 2013 2:27 am | |
| - ASPENDELL ROVER wrote:
- I made 2 cuts just a pussy hair from the threads on the shaft then hit it with the impact and came right off
Sounds like a plan to me! Steve | |
| Subject: Re: Nut on Secondary Wed Jun 12, 2013 8:52 am | |
- its gotta be something with the 08. thats 3 on 1 thread. I had to buy a new fan too.
Mine's asn 08. I have never had any prob with the secondary ; but , I've had to cut the primary off twice !!...one time was my fault...NEVER NEVER use any thread-locker on them !!! | |
4x4ff
| Subject: Re: Nut on Secondary Wed Jun 12, 2013 11:14 pm | |
| Well I got that rat bastard nut off. Had to use a dremel on it but it finally broke loose. What a pain. As an added bonus not only had the previous owner installed a JBS Sheave but I also found out I have the purple spring on the secondary..whoot.
Funny thing was I had it apart a few weeks ago and didn't even notice. I was even thinking of getting one.
Now I just have to wait for my parts to get here from WV.
Steve | |
| Subject: Re: Nut on Secondary Wed Jun 12, 2013 11:42 pm | |
scotearl
Posts : 17 Join date : 2013-05-21 Location : Arkansas
| Subject: Re: Nut on Secondary Fri Jun 14, 2013 1:10 pm | |
| While I have everything apart waiting on my new clutch, I figured I'd do a simple service on the secondary sheave. I removed it with no drama (thankfully). I then watched James' video on using one of the wheels to compress the spring while loosening the nut with an impact wrench. VERY nice idea.
My problem - where do you get a 1-13/16" socket? Are they available for a for a 1/2" drive?
Can I use a crescent wrench or channel locks once I get the spring compressed? | |
PA. GRIZZLY
Posts : 24 Join date : 2013-03-11
| Subject: Re: Nut on Secondary Fri Jun 14, 2013 1:13 pm | |
| Try Tractor Supply for the socket. | |
| Subject: Re: Nut on Secondary Fri Jun 14, 2013 1:15 pm | |
| Subject: Re: Nut on Secondary Fri Jun 14, 2013 6:50 pm | |
| northern tool for the socket an a 1/2 to 3/4 adapter I have the Milwaukee 1/2 impact with cord (110 volt) | |
| Subject: Re: Nut on Secondary Sat Jun 15, 2013 10:36 am | |
| You may be able to do it with pliers , or channel locks , if you have some help. Really no need to buy a "high-dollar" socket...I use an el-cheapo 3/4 drive with a reducer to 1/2. | |
| Subject: Re: Nut on Secondary Sat Jun 15, 2013 10:49 am | |
- I made 2 cuts just a pussy hair from the threads on the shaft then hit it with the impact and came right off LOL!!!
| Subject: Re: Nut on Secondary Sat Jun 15, 2013 3:53 pm | |
| squirt some Kroil penetrant on it and let it set overnight. that shit works wonders | |
| Subject: Re: Nut on Secondary | |
