In total there are 29 users online :: 0 Registered, 0 Hidden and 29 Guests :: 2 Bots
2009 duck unlimited 700 EFI rhino Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
2009 duck unlimited 700 EFI rhino Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
2009 duck unlimited 700 EFI rhino Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
2009 duck unlimited 700 EFI rhino Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
2009 duck unlimited 700 EFI rhino Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
2009 duck unlimited 700 EFI rhino Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
2009 duck unlimited 700 EFI rhino Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
2009 duck unlimited 700 EFI rhino Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
2009 duck unlimited 700 EFI rhino Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
2009 duck unlimited 700 EFI rhino Vote_lcap2009 duck unlimited 700 EFI rhino Voting_bar2009 duck unlimited 700 EFI rhino Vote_rcap
newfie bullet
7 posters
newfie bullet
2009 duck unlimited 700 EFI rhino Empty
PostSubject: 2009 duck unlimited 700 EFI rhino   2009 duck unlimited 700 EFI rhino Icon_minitimeTue Jun 11, 2013 11:08 pm
traded my 2009 450 rhino today on a 2009 700 EFI duck unlimited .....took it for a ride this evening and i got 49 MPH ??? the original owner put a new cdi in it but never touched the clutch?
will tha cdi get this much speed ?a friend of mine got a 2008 700 efi and his only goes 39 mph and hits the rev limiter. his seems to have a bit more torque than mine and mine seems to be a little quieter at cruising speeds like it is geared a bit higher.....is the ducks unlimited models the same as the rest or is the gearing a little different.
newfie bullet
PostSubject: Re: 2009 duck unlimited 700 EFI rhino   2009 duck unlimited 700 EFI rhino Icon_minitimeTue Jun 11, 2013 11:18 pm
I have an 07, only mod is cdi, stock size tires, and recently serviced stock clutch. I hit 52 and believe it had a tad more left...I am by no means an expert, rhino is new to me, but I think all the "gearing" is same in a ducks unlimited and the rest of the lineup of the 700's. Maybe someone else will chime in
PostSubject: Re: 2009 duck unlimited 700 EFI rhino   2009 duck unlimited 700 EFI rhino Icon_minitimeTue Jun 11, 2013 11:26 pm
The Ducks Unlimited is the same as all the rest with the exception of color.
If You can hit 49 with a stock clutch that is very good for a 700. The next thing You will want is a JBS sheave kit. It will give You a lot better low end and engine braking and also add some top end. Best mod You can do on a Rhino !!!!!!!!!!!!!!!!!
thekrust
thekrust
PostSubject: Re: 2009 duck unlimited 700 EFI rhino   2009 duck unlimited 700 EFI rhino Icon_minitimeWed Jun 12, 2013 12:07 am
Most of the aftermarket cdi's raise the rev limit by 1000rpm. Prob the cause of the increased speed.
PostSubject: Re: 2009 duck unlimited 700 EFI rhino   2009 duck unlimited 700 EFI rhino Icon_minitimeWed Jun 12, 2013 12:08 am
JBS sheave should be next, save your pennies..lol
PostSubject: Re: 2009 duck unlimited 700 EFI rhino   2009 duck unlimited 700 EFI rhino Icon_minitimeWed Jun 12, 2013 7:58 am
JBS sheave for shure you will be glad you did.
PostSubject: Re: 2009 duck unlimited 700 EFI rhino   2009 duck unlimited 700 EFI rhino Icon_minitimeFri Jun 14, 2013 7:22 pm
JBS sheave an enjoy
»  2009 Yamaha Rhino 700 EFI, Ducks Unlimited Edition
» 2009 Rhino 700
» 2009 Rhino SE
» 2009 rhino
» 2009 700 rhino wont start in gear
