| Tack | |
+4flimmy REDRHINO64 ASPENDELLROVER rhino727 8 posters |
| Subject: Tack Fri Jun 14, 2013 8:55 pm | |
| getting ready to get tack for the ride, is the Equus 8068 the one some are using on the 660 . when I went to order it said that it could be set for 4-6-8 cylinders. so not sure if it will work or not . | |
| Subject: Re: Tack Fri Jun 14, 2013 9:13 pm | |
| some guys have luck with it, but I could not get it to work. James tried 2 or 3 tach with no luck | |
| Subject: Re: Tack Fri Jun 14, 2013 9:49 pm | |
| Same tach as I have...works great...I think you set it up as a 2 cylinder to get the rpms to match up,but I have been running this same tach for 2 years and no problems!!it comes with a connection that hooks up to the spark plug wire. | |
| Subject: Re: Tack Fri Jun 14, 2013 10:01 pm | |
| Subject: Re: Tack Fri Jun 14, 2013 11:19 pm | |
| - rhino727 wrote:
- getting ready to get tack for the ride, is the Equus 8068 the one some are using on the 660 . when I went to order
it said that it could be set for 4-6-8 cylinders. so not sure if it will work or not . Seems like when we discussed this before, that tach works on the 660's but not the 700's | |
| Subject: Re: Tack Sat Jun 15, 2013 12:03 am | |
| good memory Larry, Jet bought one, wonder if it worked on his 2012? | |
| Subject: Re: Tack Sat Jun 15, 2013 2:18 am | |
| thanks for the info, thought that this was the one talked about before just wanted to make sure , will order today | |
| Subject: Re: Tack Sat Jun 15, 2013 9:12 am | |
| mine works great on my 660 most issues seem to be with the 700's | |
| Subject: Re: Tack Sat Jun 15, 2013 9:13 am | |
| i never got one to work on the 700 | |
Wingman
| Subject: Re: Tack Sat Jun 15, 2013 9:46 am | |
| On the 660's it also depends on the CDI you have also!! | |
| Subject: Re: Tack Sat Jun 15, 2013 9:48 am | |
| - Wingman wrote:
- On the 660's it also depends on the CDI you have also!!
Do You remember which ones it works with and which ones it does not ? | |
| Subject: Re: Tack Sat Jun 15, 2013 10:45 am | |
| wont work with msd,other than that I think it will work with any,i have the dynatek programmable cdi.the 8068 tach comes with a inductive pick up that goes around your spark plug wire.hope this helps | |
Wingman
| Subject: Re: Tack Sat Jun 15, 2013 11:50 am | |
| It won't work with James's buddy's CDI (Hunterworks). It has been 5-6 years since I was trying to get one to work. | |
| Subject: Re: Tack Sat Jun 15, 2013 12:16 pm | |
| I have dyna not programmable, would tack work with this | |
| Subject: Re: Tack Sat Jun 15, 2013 12:24 pm | |
| Subject: Re: Tack | |
| Tack | |
