In total there are 54 users online :: 0 Registered, 0 Hidden and 54 Guests :: 2 Bots
+3 and teryx shocks Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
+3 and teryx shocks Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
+3 and teryx shocks Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
+3 and teryx shocks Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
+3 and teryx shocks Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
+3 and teryx shocks Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
+3 and teryx shocks Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
+3 and teryx shocks Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
+3 and teryx shocks Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
+3 and teryx shocks Vote_lcap+3 and teryx shocks Voting_bar+3 and teryx shocks Vote_rcap
 +3 and teryx shocks
2 posters
Mud Rat
+3 and teryx shocks Empty
PostSubject: +3 and teryx shocks   +3 and teryx shocks Icon_minitimeMon Jul 08, 2013 5:27 pm
will the teryx shocks work on a mid travel without installing the rears upside down????
PostSubject: Re: +3 and teryx shocks   +3 and teryx shocks Icon_minitimeMon Jul 08, 2013 5:37 pm
No...the reason the rears need to be installed upside down is due to the width of the shock body where they bolt to the frame/A-arm mounts. A mid/long travel designed for the Rhino isn't going to solve that problem because they are designed to take a Rhino shock. Basically you'd need to cut the shock mounts, widen them and then re-weld
Mud Rat
PostSubject: Re: +3 and teryx shocks   +3 and teryx shocks Icon_minitimeMon Jul 08, 2013 5:44 pm
 I understand I will have to modify the shock but I was hoping with the different a-arms I can install it right side up
PostSubject: Re: +3 and teryx shocks   +3 and teryx shocks Icon_minitimeMon Jul 08, 2013 5:53 pm
I don't think you understand the issue and why they get turned upside down. Changing the length of the A-arm won't solve the problem. The shock gets flipped upside down in the rear because the lower shock mount is wider than the top shock mount The width of the mount itself is the issue not the shock...modifying the shock isn't an option...you would need to widen the top mount so the shock itself would fit.
Mud Rat
PostSubject: Re: +3 and teryx shocks   +3 and teryx shocks Icon_minitimeMon Jul 08, 2013 6:00 pm
 your right I didn't understand...lol I thought the spring width was the issue..i want to lift my rhino but don't want to stress my cv's or loose stability that's why I was thinking of doing the +3 and teryx shocks
Mud Rat
PostSubject: Re: +3 and teryx shocks   +3 and teryx shocks Icon_minitimeThu Jul 11, 2013 6:21 pm
what about using front shocks all the way around??
Mud Rat
PostSubject: Re: +3 and teryx shocks   +3 and teryx shocks Icon_minitimeFri Sep 13, 2013 8:41 pm
there's been some questions about a +3 mts and teryx shocks this is what I've done so far... I got the lonestar +3 and teryx shocks, installed the front with no problems.. I cant get the rear passenger side shock on because the axle is hitting the frame... the drivers side wont rotate without binding up so im going to relocate the mounts on the a-arms to allow the shocks to be right side up and keep the axles working properly...
+3 and teryx shocks
» stock front shocks +cfm and teryx rear shocks no cfm
» Teryx shocks??
» teryx shocks
» teryx shocks?
» Teryx Shocks
