| Wide band O2 Sensor location where is best?? | |
| Subject: Wide band O2 Sensor location where is best?? Mon Jul 22, 2013 12:02 am | |
| I am fixing to have a O2 sensor installed in my exhaust for my A/F gauage and was wondering where is the best spot for the most accurate readings and not get to hot from header heat. My buddies is in the U pipe section with spring ends at the rear and thats where I was thinking about putting mine any thoughts?? Also kicked around right before the first set of springs but figured it was close enough to header pipe might not last too long but then when you look at the Alba exhaust its about that close where theres is... | |
| Subject: Re: Wide band O2 Sensor location where is best?? Mon Jul 22, 2013 12:08 am | |
| I think it was the Muzzy duals I remember the O2 sensor bung in now that I get to thinking. | |
| Subject: Re: Wide band O2 Sensor location where is best?? Mon Jul 22, 2013 1:47 am | |
| James put mine in the rear most part of the U. | |
| Subject: Re: Wide band O2 Sensor location where is best?? Mon Jul 22, 2013 11:30 am | |
thekrust
| Subject: Re: Wide band O2 Sensor location where is best?? Mon Jul 22, 2013 12:26 pm | |
| AEM install instructions say 18" from exhaust port. | |
| Subject: Re: Wide band O2 Sensor location where is best?? Mon Jul 22, 2013 12:36 pm | |
| So it sounds like in the U pipe is a good location. | |
| Subject: Re: Wide band O2 Sensor location where is best?? Mon Jul 22, 2013 2:22 pm | |
| Well my appointment is tomorrow to get my o2 bung welded in and I can't wait to have it working I got my gauage installed over the weekend and o2 wire ran the to rear and all neated up just got to plug it in sensor. | |
| Subject: Re: Wide band O2 Sensor location where is best?? Mon Jul 22, 2013 2:58 pm | |
| Hump is yours about where mine is. | |
| Subject: Re: Wide band O2 Sensor location where is best?? Tue Jul 23, 2013 3:56 am | |
| Yeah. Mine is maybe 1 1/2 inches to the right of where yours is, but the angle is about the same. I was doing some reading on the bazzaz site, and it was talking about having it angled down like that to increase the life of the sensor. Yours should be just fine. | |
| Subject: Re: Wide band O2 Sensor location where is best?? Tue Jul 23, 2013 8:38 am | |
| You know what else increases the sensors life?? Not running leaded fuel like for racing or riding around ask Kevin about that one!! | |
| Subject: Re: Wide band O2 Sensor location where is best?? Wed Jul 24, 2013 11:31 am | |
| Well sensor is installed!! [img] [/img] [img] [/img] | |
| Subject: Re: Wide band O2 Sensor location where is best?? | |
