| Ran into problems | |
+3thekrust CUSTOMIZEDRHINO13 Rhino686 7 posters |
Rhino686
Posts : 116 Join date : 2013-07-04 Age : 26 Location : Huntington
| Subject: Ran into problems Wed Jul 24, 2013 11:59 pm | |
| Was out in the rhino today for the first ride amd about 15 miles of riding it starts making a bangimg noise. Its not the motor because it doesnt do it while sitting still but all i knew when i got the rhino was the back brakes were bad so im not sure what it could be | |
| Subject: Re: Ran into problems Thu Jul 25, 2013 12:06 am | |
| Congrats its finally here! Like a backfire or suspension wise? | |
Rhino686
| Subject: Re: Ran into problems Thu Jul 25, 2013 12:09 am | |
| No it sounds like the brake calaper is fell off amd is banging around | |
thekrust
| Subject: Re: Ran into problems Thu Jul 25, 2013 12:28 am | |
| Check if exhaust mount is broke. | |
| Subject: Re: Ran into problems Thu Jul 25, 2013 5:57 am | |
| Need more info...pretty hard to point you in the right direction with such little to go on. Look around for loose stuff, make sure the bed is latching correctly, same with the tailgate. I get a rattle and it drives me crazy until I locate it....half the time it's my seat belt rattling around because Im not wearing it. One time I was hearing a sort of bang on bumps and it was my frigin cage. The whole thing had rattled loose | |
Rhino686
| Subject: Re: Ran into problems Thu Jul 25, 2013 8:13 am | |
| I hate hearing any noise like bangs or squeeking while riding it drives me crazy also | |
| Subject: Re: Ran into problems Thu Jul 25, 2013 8:19 am | |
| You mentioned the rear brakes,have a good look at the park brake caliper,pads,support,pins and rotor.Move outboard to the rear calipers if equipped don't no what model year,same thing backing plates,or even rocks stuck some where. | |
Rhino686
| Subject: Re: Ran into problems Thu Jul 25, 2013 8:21 am | |
| Ok i will do that thanks, also while riding on my spedo and odd the reverse light is on plus the high gear light is on at the same time while in high or low | |
thekrust
| Subject: Re: Ran into problems Thu Jul 25, 2013 3:22 pm | |
| Reverse indicator switch is going bad. It will hit the reverse rev limiter when the light is on. Easy part to change. | |
| Subject: Re: Ran into problems Thu Jul 25, 2013 4:08 pm | |
| - thekrust wrote:
- Reverse indicator switch is going bad. It will hit the reverse rev limiter when the light is on. Easy part to change.
Or, the green with white stripe wire going to that switch has become disconnected (or corroded connection) somewhere along the way. | |
| Subject: Re: Ran into problems Thu Jul 25, 2013 5:27 pm | |
| With the key off,check the connections to ground,check the fuse panel for dirt and or corrosion,get it all cleaned and dielectric compound on the connectors. Finally check the plugs on you CDI for dirt,corrosion or loose pins, Make sure everything is blown out and dirt and water free. | |
Unit6666
Posts : 32 Join date : 2013-07-07
| Subject: Re: Ran into problems Thu Jul 25, 2013 5:34 pm | |
| Uhhhhh it's almost certainly that wire Steve spoke of. | |
| Subject: Re: Ran into problems | |
