In total there are 15 users online :: 0 Registered, 0 Hidden and 15 Guests :: 1 Bot
carb leaking... need a new cv shaft drivers rear Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
carb leaking... need a new cv shaft drivers rear Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
carb leaking... need a new cv shaft drivers rear Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
carb leaking... need a new cv shaft drivers rear Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
carb leaking... need a new cv shaft drivers rear Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
carb leaking... need a new cv shaft drivers rear Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
carb leaking... need a new cv shaft drivers rear Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
carb leaking... need a new cv shaft drivers rear Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
carb leaking... need a new cv shaft drivers rear Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
carb leaking... need a new cv shaft drivers rear Vote_lcapcarb leaking... need a new cv shaft drivers rear Voting_barcarb leaking... need a new cv shaft drivers rear Vote_rcap
2 posters
Unit6666
carb leaking... need a new cv shaft drivers rear Empty
PostSubject: carb leaking... need a new cv shaft drivers rear   carb leaking... need a new cv shaft drivers rear Icon_minitimeSat Jul 27, 2013 2:46 pm
Welp the work never ends with this rhino..... I noticed the seal at the bowl was seeping a bit so i gotta pull the carb off and replace the oring I guess. Does anyone know where i can get just the O-ring i don't know alot about carbs so I don't really wanna rebuild everything it seems to run pretty sweet right now. Also does anyone have a stock 06 drivers side rear complete cv shaft they wanna sell??? in good condition of course.
i would also like to change out the shitty bowl screws to allens or bolt style anyone know the size for a stock carb...
PostSubject: Re: carb leaking... need a new cv shaft drivers rear   carb leaking... need a new cv shaft drivers rear Icon_minitimeSat Jul 27, 2013 3:16 pm
is this for a stock 06 660? that would be a 42 mm Mikuni BSR
you should be able to cross reference from parts fiche for size and get stainless allen head capscrews at your local hardware store. while you're in there check for a carb rebuild kit. they aren't that much money and you'll have spares.
i'm sure james could hook you up with a rebuild kit...bounce
might as well take it apart and replace any bad parts if needed. if the float bowl has a green coloring (from ethanol) you'll want to clean it anyway.
Unit6666
PostSubject: Re: carb leaking... need a new cv shaft drivers rear   carb leaking... need a new cv shaft drivers rear Icon_minitimeSat Jul 27, 2013 4:19 pm
I don't know shit about carbs I didnt wanna mess anything up while i was poking around in there... i dunno..
Everytime I have to read about needle clips and stuff I get a nose bleed..
Anyhow how much is a rebuild kit with some allen head screws James??
Unit6666
PostSubject: Re: carb leaking... need a new cv shaft drivers rear   carb leaking... need a new cv shaft drivers rear Icon_minitimeSat Jul 27, 2013 11:07 pm
Ok so I yanked the carb.. I was looking at the carb schematic and it has 2 jet main listed 1 is a 145 and 1 is a 60? I can't actually tell from the image where the 60 is going? Also probably a dumb question I know the throttle cable opens the air flap thing but what moves the throttle valve? I noticed its spring loaded but when I push the gas it doesn't seem to move only the air flapper behind it? O and my float bowl o-ring has gone to shit as I suspected inside of carb was actually pretty clean.
PostSubject: Re: carb leaking... need a new cv shaft drivers rear   carb leaking... need a new cv shaft drivers rear Icon_minitimeSat Jul 27, 2013 11:32 pm
the 145 is the main jet and it goes inside the long perforated tube.
the other jet screws into the body of the carb where you took it out.
the throttle valve won't move until the vacuum from the running engine "pulls" it up.
if an o-ring is all you need you can buy that separately, along with replacement screws.
Unit6666
PostSubject: Re: carb leaking... need a new cv shaft drivers rear   carb leaking... need a new cv shaft drivers rear Icon_minitimeSun Jul 28, 2013 12:42 am
Thank you that answered my question.
