In total there are 49 users online :: 0 Registered, 0 Hidden and 49 Guests :: 1 Bot
Brute Force Wheels on a Rhino Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Brute Force Wheels on a Rhino Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Brute Force Wheels on a Rhino Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Brute Force Wheels on a Rhino Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Brute Force Wheels on a Rhino Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Brute Force Wheels on a Rhino Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Brute Force Wheels on a Rhino Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Brute Force Wheels on a Rhino Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Brute Force Wheels on a Rhino Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Brute Force Wheels on a Rhino Vote_lcapBrute Force Wheels on a Rhino Voting_barBrute Force Wheels on a Rhino Vote_rcap
5 posters
renegademxz
renegademxz
Brute Force Wheels on a Rhino Empty
PostSubject: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeFri Aug 09, 2013 12:43 am
I found an awesome deal on a new take off set of factory Brute Force rims with tires.
I know the bolt pattern (4 x 110mm) is the same but is the offset the same and will they fit on Rhino?
What about wheel nuts?
Any one know???
PostSubject: Re: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeFri Aug 09, 2013 8:42 am
I think they are the same off set 5+2,Force and Rhino,5" inside towards the frame and 2" outside facing you.
PostSubject: Re: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeFri Aug 09, 2013 12:28 pm
bolt pattern is the same,  but sure about the stock rim  offset.  I swapped rims and tires with my pops and he has a brute....
PostSubject: Re: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeFri Aug 09, 2013 12:30 pm
[url=Brute Force Wheels on a Rhino 20130710]
PostSubject: Re: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeFri Aug 09, 2013 1:12 pm
Wow what a transformation,looks like your ready for some mud now:!: Exclamation
PostSubject: Re: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeFri Aug 09, 2013 5:15 pm
Lol if I could get it to run right
PostSubject: Re: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeFri Aug 09, 2013 5:27 pm
You installed spacers? I couldn't install factory brute wheels on mine without spacers!!
PostSubject: Re: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeFri Aug 09, 2013 6:37 pm
Looks great!!
my  dad's are not stock,  the ones in the pic are maxxis 4x4  rims
PostSubject: Re: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeFri Aug 09, 2013 9:29 pm
That makes sense why Eric could not fit the OEM wheels on his Rhino,the off set must be different than the spec I had. The off set may be stamped into the wheels.
PostSubject: Re: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeMon Aug 12, 2013 2:30 pm
So it's not stock brute wheels?? Got ya. I tried stock brute wheels.
renegademxz
renegademxz
PostSubject: Re: Brute Force Wheels on a Rhino   Brute Force Wheels on a Rhino Icon_minitimeWed Aug 14, 2013 1:44 am
These are the cast aluminum 6 spoke black wheels I believe they are a 5+2 offset just like the stock SE Yamaha rims so I am pretty sure they will fit.
» My wheels and tires
» are grizzly and rhino wheels the same
» new wheels
» need wheels
» Looking for Griz wheels
