I had this same kit on my rhino and the remote went bad and in the process of warranty mine I ended up with the new model with smaller water tight brain and I have no use for it since I have the old version and my remote was the only issue. This is brand new in package never used or hooked up however I did open the front to see if remote would work my old system and to confirm my remote was bad and then I put the new remote back into the packing. paid $130 for this new one and will take $120 shipped details below and I will take PayPal.
WARN Wireless Control System
Warn Industries has developed a new Wireless Control System to be used with most WARN® powersports winches. You spoke, WARN listened. This Wireless Control System is designed from the ground up to suit your needs. The system is quick and easy to install, thanks to an integrated antenna and the included mounting hardware. The system allows you to operate your winch from anywhere within a 50' radius, increasing your recovery options.
- Works with any WARN Powersports winch with a contactor and a mini-rocker control switch
- Operates your winch from anywhere within a 50' radius
- Built-in antenna and included hardware allows for quick and easy installation
- Activation process and recessed buttons prevent accidental winch activation
- Two color LED indicates when the system has powered on (green) and when the system has begun winching (red). Blinking red LED indicates low battery life.
- System automatically powers off to conserve battery life
- Waterproof and rugged receiver ignores interference from other signals
- Ergonomically designed handheld remote has large buttons for easy use - even when wearing gloves
- Works at all vehicle voltage levels that allow winch operation
- All components are weatherproof
