In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests :: 2 Bots
OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
OOPS.  Watch those bolts on the primary cage thingy. Vote_lcapOOPS.  Watch those bolts on the primary cage thingy. Voting_barOOPS.  Watch those bolts on the primary cage thingy. Vote_rcap
3 posters
Tunderslimer
Tunderslimer
OOPS.  Watch those bolts on the primary cage thingy. Empty
PostSubject: OOPS. Watch those bolts on the primary cage thingy.   OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeWed Aug 28, 2013 11:32 pm
Does anyone loctite those 4 bolts that hold the primary clutch shaft bearing support thingy... I had one come out and... well... make a huge mess.  Almost ruined a riding weekend but luckily I carry a spare belt.
James, can you PM me a price on your recommended belt?  Someone... probably James... once said I can run a 700 belt on my 660 and it's better because it has kevlar in it.  Not that kevlar would have saved this one, but a better belt is better than a crappy belt.
PostSubject: Re: OOPS. Watch those bolts on the primary cage thingy.   OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeThu Aug 29, 2013 1:22 am
use oem belts, and did you follow correct torque specs?
PostSubject: Re: OOPS. Watch those bolts on the primary cage thingy.   OOPS.  Watch those bolts on the primary cage thingy. Icon_minitimeThu Aug 29, 2013 1:58 am
that sux...i never use loctite on them..100 on the 700 oem belt
