In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests
Sheave Cover Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Sheave Cover Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Sheave Cover Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Sheave Cover Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Sheave Cover Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Sheave Cover Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Sheave Cover Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Sheave Cover Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Sheave Cover Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Sheave Cover Vote_lcapSheave Cover Voting_barSheave Cover Vote_rcap
 Sheave Cover
2 posters
Shevalik
Sheave Cover Empty
PostSubject: Sheave Cover   Sheave Cover Icon_minitimeSat Aug 31, 2013 1:37 pm
Do you have to use the sheave cover for the sheave?  I ask that because the eight screws came loose and the cover worked its way off.  I believe that the threaded holes are wallered out and damaged.  I will probably have to redrill and tap them in order for them to be secure.
Sheave Cover Empty
PostSubject: Re: Sheave Cover   Sheave Cover Icon_minitimeSat Aug 31, 2013 1:52 pm
You only need the cover if you run the sheave greased
Shevalik
Sheave Cover Empty
PostSubject: Re: Sheave Cover   Sheave Cover Icon_minitimeSat Aug 31, 2013 6:39 pm
Excellent news   thanks!
Sheave Cover Empty
Sheave Cover
» Sheave cover and o-ring
» Leaking Clutch Cover!
» homemade battery cover
» Ryde on dust cover
» Rhino cover suggestions please
