| exhaust glowing red hot? | |
desertratrory
Posts : 5 Join date : 2013-09-11 Location : el paso tx
| Subject: exhaust glowing red hot? Tue Oct 01, 2013 9:14 am | |
| the other night I was out riding and noticed the exhaust header was glowing red hot is this common or how do I fix it ? its on an 06 660 | |
| Subject: Re: exhaust glowing red hot? Tue Oct 01, 2013 9:26 am | |
| Very possibly running to lean. And that is dangerous. Can melt down a good motor. The "for sure" way to find out would be an Air / Fuel gauge. The other way is a little trial on error (running a bigger main jet in Your carb).
Before we get crazy tho, tell us about Your machine....aftermarket CDI ? Sheave kit? any mods to the carb or intake? After market exhaust? | |
desertratrory
| Subject: Re: exhaust glowing red hot? Tue Oct 01, 2013 9:58 am | |
| good point ok motor has been rebuilt .5mm over, msd cdi, stock carb and alba exhaust but about 2 years ago I was riding in north florida with stock exhaust and noticed the same deal I figured it was just from altitude change as I reside and ride mainly in far west tx sadly I never paid attention to it much until the other night back to motor lol its basically stock no major mods although would like a jbs sheave in near future | |
| Subject: Re: exhaust glowing red hot? Tue Oct 01, 2013 10:12 am | |
| I'm thinking You will want to rejet the carb.
Lets see what others think about this. Lots of very good 'motor heads' on here that know it better than I do. | |
| Subject: Re: exhaust glowing red hot? Tue Oct 01, 2013 10:13 am | |
desertratrory
| Subject: Re: exhaust glowing red hot? Tue Oct 01, 2013 10:29 pm | |
| larry, fire fighter thanks I appreciate all your help and will listen to all suggestions and read up on things plus I do have a motor buddy that is knowledgeable? on these motors just want as much info as I can get and go from there all is helpfull | |
| Subject: Re: exhaust glowing red hot? Wed Oct 02, 2013 1:17 am | |
| whats the plug look like , the af gage is best but the plug color will tell you a lot also if you where hammering it right before you saw it glowing could be it the pipes get hot an at night after a hard run you can see it some times | |
desertratrory
| Subject: Re: exhaust glowing red hot? Wed Oct 02, 2013 8:21 am | |
| haven't had a chance to dig into it yet to look but can tell ya this its not from hard riding when we go out its just easy goin and most times my 10 year old drives. and good point on the plug hadn't thought about scoping it out guess if its white time to get a gauge on it and see about jettin it | |
desertratrory
| Subject: Re: exhaust glowing red hot? Sun Oct 06, 2013 9:09 am | |
| ok pulled the plug it was like a " rusty" brownish color i'm no pro but thought that was good but plug gap was only like .023 - .025 would that cause the heat? | |
| Subject: Re: exhaust glowing red hot? | |
