In total there are 45 users online :: 0 Registered, 0 Hidden and 45 Guests :: 1 Bot
04 style intake??? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
04 style intake??? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
04 style intake??? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
04 style intake??? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
04 style intake??? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
04 style intake??? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
04 style intake??? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
04 style intake??? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
04 style intake??? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
04 style intake??? Vote_lcap04 style intake??? Voting_bar04 style intake??? Vote_rcap
 04 style intake???
Crusty
7 posters
04 style intake??? Empty
PostSubject: 04 style intake???   04 style intake??? Icon_minitimeThu Oct 17, 2013 7:35 am
I hear people talking about it and how it quiets the cab down.  anyone have any pictures and some info on how to do it?  sounds like what im looking for.  I know you have to clean your air filter more often but thats a small price to pay really in my mind.
PostSubject: Re: 04 style intake???   04 style intake??? Icon_minitimeThu Oct 17, 2013 8:58 am
Remove the short snorkel tube between the air box and ram air vent on the arm rest. Then you can plug off the vent on the ram air intake with what ever works best for you. Pretty simple operation. Try it out easy to put back if you want. Dancing Banana
Crusty
Crusty
PostSubject: Re: 04 style intake???   04 style intake??? Icon_minitimeThu Oct 17, 2013 9:36 am
Just make sure that if you do put it back to OEM that you remove whatever you covered the air vent with lol
after I put mine back to OEM I forgot to remove the Duct tape and an hour later when I decided to start it, it wouldn't start and I kept thinking WTF? it was running fine a little while ago and then it hit me I forgot to remove the tape and it was sealing off the intake Very Happy
04rhino
PostSubject: Re: 04 style intake???   04 style intake??? Icon_minitimeThu Oct 17, 2013 12:40 pm
I have an 04 660 Rhino..to quiet mine down I snokeled it to right behind the frt grill..then added a trackter filter from home depot to the frt..just resultly bought a pre-filter for the uni-filter..so far works very well..found the snokel info from the "other site " years ago..do a search, think it was under quieting...also I added the Benz silencer muffler behind the factory unit..had exhaust tip moded  to 1 1/2 id  / 11/2 od..cut out factory  11/8 od & had new one welded in..just a thought..Danny
PostSubject: Re: 04 style intake???   04 style intake??? Icon_minitimeThu Oct 17, 2013 6:25 pm
Here is some good reading on the subject........
https://hotrodrhinoforums.forumotion.com/t420-re-jetting-a-carb
PostSubject: Re: 04 style intake???   04 style intake??? Icon_minitimeThu Oct 17, 2013 6:58 pm
I just removed the tube on top of the air box that attaches to the inlet on the cover. Covered the vent (on the cover) and it did decrease the noise. I have been messing with the carb lately and need a good place to buy some jets. Where is the best place to get um? These things are for sure lean from the factory. I don't have an AFM, but after adjusting the a/f screw, I can smell the richness in the exhaust now at idle. Also starts a ton better.
PostSubject: Re: 04 style intake???   04 style intake??? Icon_minitimeThu Oct 17, 2013 7:52 pm
got mine from jetsrus.com check there site, they have a great selection of carb stuff
04 style intake???
» 04 style intake
» New Air Intake?
» K&N INTAKE COMPLETE
» Salamanders in intake box...not good
