In total there are 48 users online :: 0 Registered, 0 Hidden and 48 Guests :: 2 Bots
vent lines Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
vent lines Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
vent lines Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
vent lines Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
vent lines Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
vent lines Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
vent lines Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
vent lines Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
vent lines Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
vent lines Vote_lcapvent lines Voting_barvent lines Vote_rcap
 vent lines
2 posters
mr sandman
mr sandman
vent lines Empty
PostSubject: vent lines   vent lines Icon_minitimeMon Dec 09, 2013 5:14 pm
does any one know what the vent lines (at least they appear to be vent lines) are for on the throttle body and behind the water pump?? ive got an 08 700. the one behind the water pump is actually on the case and not the pump and sometimes has some really nasty black oil drip from it. im wondering if i should run these up or what to do with them bc im snorkeling the bike. thanks in advance
vent lines Empty
PostSubject: Re: vent lines   vent lines Icon_minitimeMon Dec 09, 2013 5:52 pm
the one on the bottom is at the water pump...it can leak oil or water depending on what seal is leaking...we have them in stock....
mr sandman
mr sandman
vent lines Empty
PostSubject: Re: vent lines   vent lines Icon_minitimeTue Dec 10, 2013 11:38 am
thanks james. ill get it from you when i place my next order bc i need some other stuff too. whats the one on the throttle body for? and do i need to run them up?
vent lines Empty
PostSubject: Re: vent lines   vent lines Icon_minitimeTue Dec 10, 2013 1:47 pm
its a breather..yep run it up then turn them down
vent lines Empty
vent lines
