Who is online? | In total there are 37 users online :: 0 Registered, 0 Hidden and 37 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | J strong top | |
+4banchee6 Hatchet1 Firefighter Deuces wild 8 posters | Author | Message |
Deuces wild
| Subject: J strong top Thu Mar 14, 2013 10:25 pm | |
| The other night I was riding and I had headlights on and all 4 lights on my top on, and the radio cut off so I turned two lights off the radio cut back on? My question is this do I need to upgrade my electrical system to run this top or is something going bad on my rhino? | |
| | | Firefighter
| Subject: Re: J strong top Thu Mar 14, 2013 10:46 pm | |
| Your probably just pulling to many amps. You need to put a meter on Your battery and check with everything off first. Should be around 12.5. Then start it up and check with nothing extra on. Should be around 13.7. If all is good so far, start turning stuff on and see what is pulling so much. If it gets below around 12.5, Your pulling more than the charging system will handle. Let Us know there is a couple solutions | |
| | | Deuces wild
| Subject: Re: J strong top Thu Mar 14, 2013 10:56 pm | |
| Every question I ask you have an answer for that's why I love this forum and that's why you should borrow santas sleigh , come to va. And hook a brother up. | |
| | | Hatchet1
Posts : 2 Join date : 2013-03-10 Age : 45 Location : Little Rock, Arkansas
| Subject: Re: J strong top Thu Mar 14, 2013 11:00 pm | |
| | | Firefighter
| Subject: Re: J strong top Thu Mar 14, 2013 11:26 pm | |
| - lambfam660 wrote:
- Every question I ask you have an answer for that's why I love this forum and that's why you should borrow santas sleigh , come to va. And hook a brother up.
HAHA Hope to meet up someday.........soon. Go for a ride !!!!!!!!!!!!!! | |
| | | banchee6
| Subject: Re: J strong top Sun Mar 31, 2013 9:50 pm | |
| the j strong top pulls some amps..... We ran a few batterys down with amps, lights, and radios...... found it worked better if we trickle the battery before the ride overnight... Just a thought | |
| | | WV Hot Rod Rhino Admin
| Subject: Re: J strong top Sun Mar 31, 2013 10:20 pm | |
| make sure the terminals are super tight too | |
| | | Wingman
| Subject: Re: J strong top Mon Apr 01, 2013 12:54 am | |
| That was the reason I removed the 4 lights on the top and installed 2 LED lights. After about 20 minutes the 4 lights were not as bright and the headlights looked yellow!! The 2 LED lights draw less power than 1 of the original lights. | |
| | | CUSTOMIZEDRHINO13
| Subject: Re: J strong top Mon Apr 01, 2013 1:40 am | |
| When my battery went out everything was flickering on and off when I would try to start it. | |
| | | Hump
| Subject: Re: J strong top Tue Apr 02, 2013 3:36 am | |
| If I had a Jstrong roof, I would replace all 4 lights with some cube leds, and I bet the problem would be solved. Plus, you would have much more light. I will never buy another aftermarket light that is not led.
I bet two spot pattern, and two flood or driving pattern cubes would be real nice in that roof. | |
| Subject: Re: J strong top | |
| | | | J strong top | |
