| axels | |
skeeter9
Posts : 171 Join date : 2013-03-10 Age : 39 Location : kommifornia
| Subject: axels Sun Mar 17, 2013 5:20 pm | |
| Ok I can get the one you open with screwdriver but how the hell do you get the other one.... I'm about to just take and label all 4 axles and see if maybe alba will do em for me before I blow a gasket | |
| Subject: Re: axels Sun Mar 17, 2013 7:43 pm | |
| More info please. I'm lost what you're trying to do? Are you trying to install? Remove? Replace the CVs? | |
skeeter9
| Subject: Re: axels Sun Mar 17, 2013 9:13 pm | |
| I'm trying to install my longer axles for my mid travel.... But gotta remove stock ones first.... Gonna label em and have alba do em for me I only have one day off a week an trying to squeeze in removing and replacing a arms plus axles wears ones patience thin causing accidents..... Yes I busted my hand good hence my screw it decision LOL | |
| Subject: Re: axels Sun Mar 17, 2013 9:39 pm | |
| - skeeter9 wrote:
- I'm trying to install my longer axles for my mid travel.... But gotta remove stock ones first.... Gonna label em and have alba do em for me I only have one day off a week an trying to squeeze in removing and replacing a arms plus axles wears ones patience thin causing accidents..... Yes I busted my hand good hence my screw it decision LOL
You having a hard time getting the stock axles out? They should just pull out straight. Compress the CV by pushing in first then pull quickly out. You shouldn't need any tools....just yank on it and give er hell. | |
| Subject: Re: axels Sun Mar 17, 2013 10:12 pm | |
| we need vids of everything!!!.... | |
| Subject: Re: axels Sun Mar 17, 2013 10:13 pm | |
skeeter9
| Subject: Re: axels Sun Mar 17, 2013 11:21 pm | |
| No they are out... the swapping of boots and cvs from stock axles to new axles | |
| Subject: Re: axels Mon Mar 18, 2013 2:57 am | |
skeeter9
| Subject: Re: axels Mon Mar 18, 2013 5:36 pm | |
| Now question are both sides done the same way?... | |
| Subject: Re: axels Tue Mar 19, 2013 10:02 am | |
| Subject: Re: axels Tue Mar 19, 2013 10:12 am | |
| If they are not level the comp ring at the end of the shaft inside the housing will bind and not compress and not allow it to pass threw the housing you have to hold the axel level and pull at the same time. It takes some time to get use to but it will come out. | |
skeeter9
| Subject: Re: axels Tue Mar 19, 2013 10:34 am | |
| Sweet thanks guys a video made it 100 times more sense than the instructions did and now I believe I can handle em myself.... As soon as I get time lol | |
Baxter Built Fabrications
| Subject: Re: axels Tue Mar 19, 2013 10:56 am | |
| The clean up is the worst part.Good time to double check the cages and CVs for damage though.Mine were spotless after 2000 miles of hard abuse. | |
skeeter9
| Subject: Re: axels Tue Mar 19, 2013 11:22 am | |
| Mine have maybe 200 miles lol | |
| Subject: Re: axels Tue Mar 19, 2013 12:08 pm | |
| just like anything once you've done it once the second time is a breeze. I youtube everything! Even if you can't find the exact video you can usually get something close. I always find a visual extremely useful! | |
skeeter9
| Subject: Re: axels Tue Mar 19, 2013 3:04 pm | |
| That's what I did with my sheave don't know why I didn't think about it with this lol | |
| Subject: Re: axels Tue Mar 19, 2013 3:18 pm | |
| I did the same...never knew what a sheave was till I opened it up. Shit, the first time I flooded my Rhino I took the entire clutch cover off because I didn't know there was a drain. 20 second job too me about an hour. | |
| Subject: Re: axels | |
| axels | |
