In total there are 35 users online :: 0 Registered, 0 Hidden and 35 Guests :: 1 Bot
hd shock springs Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
hd shock springs Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
hd shock springs Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
hd shock springs Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
hd shock springs Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
hd shock springs Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
hd shock springs Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
hd shock springs Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
hd shock springs Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
hd shock springs Vote_lcaphd shock springs Voting_barhd shock springs Vote_rcap
 hd shock springs
3 posters
hd shock springs Empty
PostSubject: hd shock springs   hd shock springs Icon_minitimeSat Mar 23, 2013 6:00 pm
hey james was kicking around the idea of the teryx shock swap, but would also like to get a price from you on the hd springs for front & rear for my rhino in case i go that route, also your opinion means a lot to me in the matter , thanks mick
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSat Mar 23, 2013 10:31 pm
is yours real heavy
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSat Mar 23, 2013 10:40 pm
i woulnt say real heavy,i do use it for firewood though w/ a small polar trailer
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSat Mar 23, 2013 11:01 pm
you have to cut the shock bolt heads down on the bottom or it will break the axles...
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 12:21 am
what do you think springs, shocks , or other
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 11:21 am
how hard are you gonna ride it
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 11:56 am
dont ride that hard anymore ,most trails are tight and rocky
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 12:16 pm
are those the original shocks
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 12:30 pm
yep
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 1:08 pm
seals may be getting old by now...might should do progressive(5-600.00) if you ride easy...bilstiens(1000.00) if you wanna ride harder...stage 4 elkas if you wanna ride like me...lol...(2300.00).....or stock sport takeoffs are great!!4-500.00
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 1:17 pm
thanks james i'll think it over i'm in no big hurry
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 1:21 pm
check around all of your and see if any are leaking
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 1:42 pm
all clean no leaks
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 2:38 pm
springs will do if no leaks
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeSun Mar 24, 2013 2:52 pm
what for all 4, hard to install?
tjt603
tjt603
PostSubject: Re: hd shock springs   hd shock springs Icon_minitimeMon Mar 25, 2013 10:56 am
how much are the hd springs ?
hd shock springs
» have you tried this for sagging springs ?????
» secondary springs
» secondary springs or weights
» Red Rock Canyon/Dove Springs
» Broken Kibblewhite Valve Springs
