| What trailer size | |
+9Kenny G madmax 1 Snorhino Hump chuddly hymarker flimmy Firefighter thekevin 13 posters |
| Subject: What trailer size Wed Mar 27, 2013 10:26 pm | |
| I have a 5x14 that I used to haul my quads on and when I went to pick up my Rhino the front tires cleared but the rears wouldnt so we had to take off the rear spacers. I am looking a 6' 4" x 10' tilt trailer but I was wondering if it would pull ok with the axle further forward because of the tilt.
| Subject: Re: What trailer size Wed Mar 27, 2013 10:30 pm | |
| I think it would be fine. I do think You will want to load it all the way to the front, with the axle being further forward. | |
| Subject: Re: What trailer size Wed Mar 27, 2013 11:02 pm | |
| Like Firefighter said load all the way to the front on a trailer that short. You dont want to load it too far to the rear you could get the trailer to sway if you dont have enough tounge weight | |
hymarker
| Subject: Re: What trailer size Wed Mar 27, 2013 11:25 pm | |
| Subject: Re: What trailer size Thu Mar 28, 2013 7:05 am | |
| i built my own trailer and i put the axle further back for this very reason. Mine is likr 6'x10' if I remember right. | |
| Subject: Re: What trailer size Fri Mar 29, 2013 12:36 am | |
| I have a 6'4" x 12' so I can move the rhino just where I want it to balance out good. That's important to me because I tow with a Tacoma, not a big ol truck. I can't have any sway at all, because when I tow, I really haul. | |
| Subject: Re: What trailer size Fri Mar 29, 2013 1:00 am | |
| I think I am going to pass on the tilt trailer, I don't want to take any chances when I have a couple of 1000+ mile trips planned already. | |
| Subject: Re: What trailer size Fri Mar 29, 2013 12:47 pm | |
| I love me some Toyota. They never made one I didn't like. Mine is a 05 TRD offroad with a 4.0 and 6 speed. I wish I had got the automatic though. 1st and reverse is way to high for turning the trailer around, and it's a pretty big jump from 1st to 2nd going up a steep hill towing. | |
Snorhino
| Subject: Re: What trailer size Fri Mar 29, 2013 8:58 pm | |
| Like some others I have a 6'4" x 12' works great , plenty of room | |
| Subject: Re: What trailer size Fri Mar 29, 2013 9:07 pm | |
| yeah, I think I am going to buy a 6'4" x 10 with a drop gate. | |
| Subject: Re: What trailer size Fri Mar 29, 2013 9:10 pm | |
| i bought a 6x10 at romney cycle in romney wv. 1100.00 with the drop gate, works great | |
| Subject: Re: What trailer size Fri Mar 29, 2013 9:12 pm | |
| I got quoted $1000 by a local guy here that makes them. | |
| Subject: Re: What trailer size Fri Mar 29, 2013 9:37 pm | |
| I went shopping around and found a good used car trailer for $600 and jumped on it. It hauls the Rhino like there isn't anything even back there and has plenty of room; if I need to haul supplies or material to our mountain property not a problem but its a full 16' if your short on a place to store it. | |
RiverRat
| Subject: Re: What trailer size Sat Mar 30, 2013 1:58 pm | |
| I've got a 6' 10" X 14" tilt. It pulls good but it is as wide as a 1ton dually. | |
| Subject: Re: What trailer size Sat Mar 30, 2013 2:13 pm | |
| I am really back and forth on buying a full size car trailer because I know once I do I will get volunteered to use it alot, but it does make sense to buy one. The trailer manufacturer here told me 1000 for the 6x10 with gate and 1200 for a 6'4"x16'. | |
| Subject: Re: What trailer size Sat Mar 30, 2013 3:45 pm | |
| I would get atleast 16ft tandem axle,thats what i have,and the tandem axle trailers pull better and if one tire goes flat you can keep going...4 tires better than 2.wish i had went ahead and got the 20ft trailer! but i can haul my rhino and my sons kfx 700 with about a foot between them and still get some gear and coolers on there.oh yea,i paid 1600 for mine. | |
| Subject: Re: What trailer size Sat Mar 30, 2013 3:52 pm | |
| Weight has a factor in this as well. I have a new crew cab Chevy and with my 14ft trailer I already drop down to under 13mpg pulling it. | |
| Subject: Re: What trailer size Sat Mar 30, 2013 4:13 pm | |
| I have a 2012 f250 and mine gets around 12mpg pulling the trailer loaded.and thats going up alot of hills to w.v. | |
| Subject: Re: What trailer size Sat Mar 30, 2013 4:34 pm | |
| Here is my truck and 16 ft trailer at camper in w.v. | |
rhinoroger
Posts : 218 Join date : 2013-03-10 Age : 64 Location : Bridgeport, WV.
| Subject: Re: What trailer size Sun Mar 31, 2013 9:16 am | |
| picked up a gator made 6'10x12 with spring assist gate in bowden wv for 1195.00 perfect size for the rhino. they also have the same trailer in a 6.5x14 for 1395.00 | |
| Subject: Re: What trailer size Tue Apr 02, 2013 11:35 pm | |
| i have a 12x6 tandem with four brakes,very stabile and has extra room for stuff when the Rhino is loaded.but its little heavy for my truck.The 12x6 in aluminum would be the way to go. | |
| Subject: Re: What trailer size | |
