| Custom Cage Covers | |
+6onebuilder CUSTOMIZEDRHINO13 skeeter9 flimmy Greeley Kenny G 10 posters |
| Subject: Custom Cage Covers Thu Mar 28, 2013 1:28 pm | |
| What have you guys with custom cages found works best for a cage roof. Also, if you're using a head-liner what is working best for you; or what would you change about your roof setup if you had to do it over? Thanks. | |
Greeley
Posts : 113 Join date : 2013-03-11 Age : 38 Location : CA
| Subject: Re: Custom Cage Covers Thu Mar 28, 2013 1:37 pm | |
| I have a 4 seat roll cage and this is not a joke but my mom stitched me up a camo canvas top for it. Added some little metal eyelets around the edges and we secure it on with velcro straps; simple, inexpensive, and effective for that desert heat! | |
| Subject: Re: Custom Cage Covers Thu Mar 28, 2013 2:21 pm | |
| I used aluminum and put some rubber tape in between the roof and cage so it wouldn't rattle. I just riveted it to the cage. | |
skeeter9
Posts : 171 Join date : 2013-03-10 Age : 39 Location : kommifornia
| Subject: Re: Custom Cage Covers Thu Mar 28, 2013 2:30 pm | |
| I was thinking about a canvas top as well... Homemade of course | |
| Subject: Re: Custom Cage Covers Thu Mar 28, 2013 2:43 pm | |
| Get a bikini top for a jeep and cut it up. That's what I did on my old rock crawler | |
| Subject: Re: Custom Cage Covers Thu Mar 28, 2013 7:53 pm | |
| I used sheet metal for my stock cage but I think it would be to heavy for a 4 seater unless its super thin. | |
| Subject: Re: Custom Cage Covers Mon Apr 01, 2013 9:10 pm | |
| Thanks for the input guys. Let-Em Buck | |
| Subject: Re: Custom Cage Covers Mon Apr 01, 2013 10:55 pm | |
| On my stock cage and my new Lone Star cage I used aluminum. I've seen to many fabric tops get snagged and rip! They also don't fare to well going down the highways. | |
| Subject: Re: Custom Cage Covers Tue Apr 09, 2013 10:35 pm | |
| Steve, How did you secure your top down? I've got tabs on the four corners. Would hold it down but would probably flex and rattle. | |
| Subject: Re: Custom Cage Covers Tue Apr 09, 2013 11:07 pm | |
| I have a sheet of stainless steel that the PO put on with the front window which is plexi glass. I like it but It rattles and i tried some campers tape with not much luck i may get more pipe insulation from the hardware store and use it in a few spots. I used a bunch of it around the kids back seat on all the braces. | |
| Subject: Re: Custom Cage Covers Tue Apr 09, 2013 11:10 pm | |
EddieMc
| Subject: Re: Custom Cage Covers Mon Apr 15, 2013 7:44 pm | |
| - flimmy wrote:
- I used aluminum and put some rubber tape in between the roof and cage so it wouldn't rattle. I just riveted it to the cage.
how hard was it to get the rivets threw all that metal??? | |
| Subject: Re: Custom Cage Covers Mon Apr 15, 2013 10:31 pm | |
| It wasn't that hard with the right rivet gun. I just used long SS rivets. I found the aluminum ones started breaking. | |
Big Dog Daddy
Posts : 152 Join date : 2013-03-11 Age : 65 Location : Kentucky
| Subject: Re: Custom Cage Covers Mon Apr 15, 2013 11:23 pm | |
| Canvas top. | |
EddieMc
| Subject: Re: Custom Cage Covers Tue Apr 16, 2013 2:37 pm | |
| - flimmy wrote:
- It wasn't that hard with the right rivet gun. I just used long SS rivets. I found the aluminum ones started breaking.
what kind of rivet gun did u drill holes first??????????? u used to weld tabs and bolt em on ur sounds easier and cheaper | |
| Subject: Re: Custom Cage Covers Tue Apr 16, 2013 5:05 pm | |
| Yep I drilled one hole at a time and a friend had a HD rivet gun. I clamped the roof to the cage using the big c channel vise grips. You have to use the SS rivets. Anything else will break after a ride or 2 | |
EddieMc
| Subject: Re: Custom Cage Covers Tue Apr 16, 2013 7:53 pm | |
| u drill the hole a little smaller then the rivet?? | |
| Subject: Re: Custom Cage Covers Tue Apr 16, 2013 8:47 pm | |
| Nope the same size, most of the rivets will tell you what size hole to drill. Drill it so it just fits. | |
| Subject: Re: Custom Cage Covers Tue Apr 16, 2013 10:23 pm | |
| I went with thin sheet metal, headliner, and small self tapping screws. Worked great and allows me to remove it if I need to. | |
| Subject: Re: Custom Cage Covers Tue Apr 16, 2013 10:32 pm | |
| - Pokahpolice wrote:
- I went with thin sheet metal, headliner, and small self tapping screws. Worked great and allows me to remove it if I need to.
Did you pre drill holes for the screws? Why I'm asking is I was enclosing the storage box under the drivers set and had some self-tapping screws from a metal building we put up and twisted two of them off about half way in. Figured if they'd go into red iron they'd go into the seat base. Screws just to weak? | |
EddieMc
| Subject: Re: Custom Cage Covers Tue Apr 16, 2013 11:44 pm | |
| - flimmy wrote:
- Nope the same size, most of the rivets will tell you what size hole to drill. Drill it so it just fits.
u got some pics of ur roof??? | |
| Subject: Re: Custom Cage Covers | |
