In total there are 30 users online :: 0 Registered, 0 Hidden and 30 Guests :: 2 Bots
Secondary Sheave grease Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Secondary Sheave grease Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Secondary Sheave grease Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Secondary Sheave grease Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Secondary Sheave grease Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Secondary Sheave grease Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Secondary Sheave grease Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Secondary Sheave grease Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Secondary Sheave grease Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Secondary Sheave grease Vote_lcapSecondary Sheave grease Voting_barSecondary Sheave grease Vote_rcap
3 posters
Secondary Sheave grease Empty
PostSubject: Secondary Sheave grease   Secondary Sheave grease Icon_minitimeFri Mar 29, 2013 8:42 pm
What are you guys recomending for grease on the inside of the secondary? BelRay, Ultramatic or???
PostSubject: Re: Secondary Sheave grease   Secondary Sheave grease Icon_minitimeFri Mar 29, 2013 9:28 pm
I used yamalube, hopefully that's right.
PostSubject: Re: Secondary Sheave grease   Secondary Sheave grease Icon_minitimeFri Mar 29, 2013 9:31 pm
manual says bel ray assembly lube but IT DOES NOT WORK...use ultra matic it does fine
PostSubject: Re: Secondary Sheave grease   Secondary Sheave grease Icon_minitimeFri Mar 29, 2013 9:32 pm
Is it the same as Yamalube right?
PostSubject: Re: Secondary Sheave grease   Secondary Sheave grease Icon_minitimeFri Mar 29, 2013 9:35 pm
yep..yama lube ultra matic
» grease in my sheave
» grease comming out of sheave
» How to Grease your Hot Rod Sheave & OD Weights
» how to get the secondary sheave out on a 660
» greasing secondary sheave
